Discuss
crt
 in
Dryer Repair
Changed heating element last week. The old one burnt in two. The dryer works but it seems to be to
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » crt
  #1 (permalink)
Old 09-29-2008, 06:55 PM
crtcn crtcn is offline
Junior Member
crtcn is on a distinguished road
Default crt
Model Number: LES5700XNOP   Brand: Whirlpool   Age: More than 10 years
Changed heating element last week. The old one burnt in two. The dryer works but it seems to be to hot. I checked both thermostats with an ohm. meter. they both were at .3 ohms
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 09-29-2008, 08:17 PM
libertyappl libertyappl is offline
Senior Expert
APP Volunteer
libertyappl is on a distinguished road
Default
Did you check them with the wires disconnected? Sounds like the high limit isn't working.
__________________
-We don't have a fancy website but, we do have fast reliable service in South Central Missouri & do warranty work for Whirlpool, Estate, Maytag, Amana, Frigidaire, Gibson & more. We service most of the South Central Ozarks region. Send us an email at libertyapplservice@yahoo.com
We are also Ministers that do a weekly jail house ministry.
Rate Liberty Appliance Service on MyPros.com
  #3 (permalink)
Old 09-29-2008, 08:32 PM
Junior Member
Default crt
Yes, when I tested the switches they were unpluged.Can you give the part # for the high limit.
  #4 (permalink)
Old 09-29-2008, 08:35 PM
Senior Expert
APP Volunteer
Default
Your model number doesn't pull up, please verify the number.
Nat
__________________
  #5 (permalink)
Old 09-29-2008, 09:34 PM
SublimeMasterJW SublimeMasterJW is offline
Senior Expert
APP Volunteer
SublimeMasterJW is on a distinguished road
Default Check the exhaust temp
It should not exceed 165ish. If it does then your cycling thermostat needs replacement.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
