Appliance Repair Forum
-   Dryer Repair (http://forum.appliancepartspros.com/dryer-repair/)
-   -   crt (http://forum.appliancepartspros.com/dryer-repair/12465-crt.html)
crtcn 09-29-2008 05:55 PM
crt
Changed heating element last week. The old one burnt in two. The dryer works but it seems to be to hot. I checked both thermostats with an ohm. meter. they both were at .3 ohms
libertyappl 09-29-2008 07:17 PM
Did you check them with the wires disconnected? Sounds like the high limit isn't working.
crtcn 09-29-2008 07:32 PM
crt
Yes, when I tested the switches they were unpluged.Can you give the part # for the high limit.
libertyappl 09-29-2008 07:35 PM
Your model number doesn't pull up, please verify the number.
Nat
SublimeMasterJW 09-29-2008 08:34 PM
Check the exhaust temp
It should not exceed 165ish. If it does then your cycling thermostat needs replacement.:D
