| » Dryer runs, but no heat |
Model Number: LGR8648LW0 Brand: Whirlpool Age: 1 - 5 years
The dryer is running fine, but no heat is produced. I checked the heating element and it isn't glowing, no ignition.
I bypassed the high limit fuses and still no ignition. I'm suspecting that the heating element has failed, but can anyone tell me if there are other probable causes I should check before I buy a new heating element? Much appreciated! Ads By Google Related Models |
Which part exactly did you bypass: the high limit thermostat (#15 on the diagram) or the thermal fuse (#7 on the diagram)?
You have to have a simple ohmmeter to check all parts involved in the heating circuit for continuity. Bypassing can help but not always. Here are the breakdown diagrams and Replacement parts for WHIRLPOOL LGR8648LW0 | AppliancePartsPros.com Here is the Wiring diagram. Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
Gene,
Thanks for your response. I bypassed numbers 15 and 16 on the diagram. I bought a new igniter element today, and still no luck. I know little to nothing about electrical, but you would suggest an ohmmeter to help locate the failure? Any ideas what may have failed if it isn't the igniter, but it's not heating up? |
Most likely the problem is a bad thermal fuse (#7).
There are at least five parts in the heating circuit and replacing them one by one just by guessing is very costly. If you would like to fix appliances (electrical problems) yourself you must have a multimeter. - The thermal fuse Part number: AP3132867 Gene.
__________________
| Display Modes | |
| Clothes dryer runs, but doest not heat (Dryer no heat | yzhong | Dryer Repair | 5 | 10-29-2009 04:54 PM |
| Gas Dryer Runs, but no heat | OKCandy | Dryer Repair | 10 | 04-18-2009 04:48 PM |
| dryer runs no heat | kwclark | Dryer Repair | 1 | 01-25-2009 06:13 AM |
| Dryer runs but won't heat. | John Drayton | Dryer Repair | 1 | 06-25-2008 04:32 AM |
| Dryer runs but doesn't heat | Jane | Dryer Repair | 3 | 08-07-2007 09:01 PM |
