Discuss
Roper help
 in
Dryer Repair
Any help would be appreciated. Has worked fine until today. Wife tells me it "won't turn back on
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Roper help
  #1 (permalink)
Old 09-28-2008, 03:00 PM
swbdd swbdd is offline
Junior Member
swbdd is on a distinguished road
Default Roper help
Model Number: REX6634PQ0   Brand: Roper   Age: 1 - 5 years
Has worked fine until today. Wife tells me it "won't turn back on after checking clothes". After looking at it myself this is what I found........
Drier "hums" (motor won't start) when door is shut AND you don't have to push the start button to get it to do that.
If I spin the drum and push the door switch it will start up , run and blow hot air. (actually finished the load that was in it that way)
While I don't know for fact, it seemed like the heating element is on even without it running as there is heat coming out of the drum. (I unplugged the drier for now)
The knob that does the different cycles and timer seems to be ticking even when set to off. And like I said I still feel heat coming out of the the drum even after 30 to 60 seconds.
The first time I looked at it today I gave it 10 minutes to cool down and it worked as normal (I had to shut door and push start button) until it did a normal cycle and dried the clothes. I reloaded it warm and problem was back.
Any ideas? I tried to add all information I could think of.
Thanks, Dave.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 09-28-2008, 04:42 PM
kayakcrzy kayakcrzy is offline
Senior Expert
APP Volunteer
kayakcrzy is on a distinguished road
Default
Yes, replace the motor. Tom ApplianceEducator.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
water in the roper D.W. Refrigerator & Freezer Repair 1 08-25-2008 08:30 PM
roper refrigerator grumpee62 Refrigerator & Freezer Repair 1 04-27-2008 04:08 AM
roper maximum destruction Washer Repair 2 01-07-2008 04:37 PM
Roper Leak Rayh Washer Repair 1 11-17-2007 10:08 AM
Roper Won't power up cmedics Dishwasher Repair 1 11-14-2007 10:18 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
