Discuss
BOSCH Convection Oven
 in
Dryer Repair
I have a Bosch electric oven with convection. The regular oven works fine. The convection element is not heating. The
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » BOSCH Convection Oven
  #1 (permalink)
Old 09-28-2008, 02:57 PM
tommett tommett is offline
Junior Member
tommett is on a distinguished road
Question BOSCH Convection Oven
Model Number: HBL642AUC   Brand: Bosch   Age: 5 - 10 years
I have a Bosch electric oven with convection. The regular oven works fine. The convection element is not heating. The convection fan still works. By replacing the element and the sensor do I solve the problem?
Related Models
Bosch HBL645
Bosch HBL646
Bosch HBL652
Bosch HBL655
Bosch HBL656
Bosch HBL662
Bosch HBL665
Bosch HBL666
Bosch HBL742 AUC (FD 8207-)
Bosch HBL745 AUC (FD 8207-)
Bosch HBL746 AUC (FD 8207-)
Bosch HBL752 AUC (FD 8207-)
Bosch HBL755 AUC (FD 8207-)
Bosch HBL756 AUC (FD 8207-)
Bosch HBL765 AUC (FD 8207-)
Bosch HBN442 AUC
Bosch HBN445 AUC
Bosch HBN446 AUC
Bosch HBN452 AUC
Bosch HBN455 AUC
Bosch HBN456 AUC
Bosch HBN642
Bosch HBN645
Bosch HBN646
Bosch HBN652
Bosch HBN655
Bosch HBN656
Bosch HBN662
Bosch HBN665
Bosch HBN666
Bosch HBN742 AUC (FD 8207-)
Bosch HBN745 AUC (FD 8207-)
Bosch HBN746 AUC (FD 8207-)
Bosch HBN752 AUC (FD 8207-)
Bosch HBN755 AUC (FD 8207-)
Bosch HBN756 AUC (FD 8207-)
Bosch HBN765 AUC (FD 8207-)
Magic Chef HC309B-2 Hood
Magic Chef HC30AB-2 Hood
Frigidaire HC30C Frg(v1) / Range Vent Hood
Frigidaire HC30CL Frg(v2) / Range Vent Hood
Frigidaire HC8830S Frigidaire / Range Hood
Frigidaire HC8830W Frigidaire / Range Hood
Frigidaire HC8836S Frigidaire / Range Hood
Frigidaire HC8836W Frigidaire / Range Hood
Hardwick HCF120 Freezer - Vertical
Hardwick HCF170 Freezer - Vertical
Hardwick HCF200 Freezer - Vertical
Hardwick HCF200A Freezer - Vertical
Hardwick HCF200H Freezer - Vertical
General Electric HCK23LCMAFCC Refrigerator
Amana HCL305 Range - S/c S/i Ddraft Gas
Amana HCL605 Range - S/c S/i Ddraft Gas
Amana HCR305 Range - S/c S/i Ddraft Gas
Amana HCR306 Range - S/c S/i Ddraft Gas
Amana HCR3061L Hood
Amana HCR3061L Hood
Amana HCR3061W Hood
Amana HCR3061W Hood
Amana HCR307E Hood
Thermador HCSW36TB
Thermador HCSW36TS
Thermador HCSW36TW
Thermador HCSW42TB
Thermador HCSW42TS
Thermador HCSW42TW
Thermador HCSW48TB
Thermador HCSW48TS
Thermador HCSW48TW
Amana HCU-514 Range - S/c S/i Ddraft Gas
Amana HCU-514C Range - S/c S/i Ddraft Gas
Amana HCU-514D Range - S/c S/i Ddraft Gas
Amana HCU-514E Range - S/c S/i Ddraft Gas
Amana HCU-516 Range - S/c S/i Ddraft Gas
Amana HCU-516A Range - S/c S/i Ddraft Gas
Amana HCU-516C Range - S/c S/i Ddraft Gas
Amana HCU-516D Range - S/c S/i Ddraft Gas
Amana HCU-516F Range - S/c S/i Ddraft Gas
Amana HD-332 Mwave - Mounted Over Range/wo
Amana HD-336 Mwave - Mounted Over Range/wo
Amana HD-342 Mwave - Mounted Over Range/wo
Whirlpool HD100
Whirlpool HD1000JSC4 Hot Water Dispenser
Whirlpool HD1000JSN4 Hot Water Dispenser
Whirlpool HD1000JSW0
Whirlpool HD1000JSW1 W - White C - Chrome N - Almond
Whirlpool HD1000JSW3 Hot Water Dispenser
Whirlpool HD1000JSW4 Hot Water Dispenser
Whirlpool HD1000XS0
Whirlpool HD1000XS2
Whirlpool HD1000XS3
Whirlpool HD1000XSC7
Whirlpool HD1000XSW4
Whirlpool HD1000XSW5
Whirlpool HD1000XSW6
Whirlpool HD1000XSW7
Whirlpool HD1000XSW8
General Electric HDA1000G00WH Dishwasher
General Electric HDA1000G02WH Dishwasher
General Electric HDA1000G20WH Dishwasher
General Electric HDA1000K01 Dishwasher
General Electric HDA1000K02 Dishwasher
General Electric HDA1000K03 Dishwasher
General Electric HDA1000Z00WH Dishwasher
General Electric HDA1000Z01WH Dishwasher
General Electric HDA1000Z02WH Dishwasher
General Electric HDA1000Z04WH Dishwasher
General Electric HDA1000Z05WH Dishwasher
General Electric HDA1000Z06WH Dishwasher
General Electric HDA1000Z07WH Dishwasher
  #2 (permalink)
Old 09-29-2008, 12:14 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Default
Remove the rear baffle (#35 on the break down diagram) and the convection heating element.
Check the heating element for continuity and replace if it's open. You do not have to replace the sensor.
If there is nothing wrong with the heating element, then remove any one wire from the heating element and check for 240VAC between these wires. Post the results.
- The part number for the convection heating element is AP3775599
Here are the break down diagrams for the Bosch oven Model HBL642
__________________
  #3 (permalink)
Old 10-29-2008, 11:13 PM
Junior Member
Default
Thanks Gene I was clearing out my e-mails and noted I hadn't replied to your advice. The element was bad per the electrical check. I ordered the part replaced it and the convection is working. Thanks so much for your help.
  #4 (permalink)
Old 10-29-2008, 11:25 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
I'm glad you were able to fix it.
__________________
  #5 (permalink)
Old 04-09-2009, 10:01 PM
cas1 cas1 is offline
Junior Member
cas1 is on a distinguished road
Default
Is this the same part for the
HBN442A ?
  #6 (permalink)
Old 04-10-2009, 01:59 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Yes, it is AP3775599
__________________
  #7 (permalink)
Old 04-10-2009, 02:02 PM
Junior Member
Default
Gene,
All oven functions work except for the Convection Bake.
Is it likely to be this round element?
Thanks,
cas1
  #8 (permalink)
Old 04-10-2009, 02:21 PM
Junior Member
Default
Thanks for the response,
Does the part AP3775599 for the Convection Bake need any seals or other things. If I need a seal or other bits, I would like to order them at the same time.
Thanks, cas1
  #9 (permalink)
Old 04-10-2009, 03:01 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
I do not think there are any seals. You can use all previous instructions for tommett.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Microwave Convection Oven bc9ltjj Microwave Repair 11 12-12-2008 12:58 AM
jenn air convection oven bushbg Oven Repair (including Ranges and Cooktops) 0 05-26-2008 11:20 AM
Convection Oven not heating well russ hibbeler Oven Repair (including Ranges and Cooktops) 3 12-11-2007 12:17 PM
Bosch Convection Oven Heating Element rochelleferris Oven Repair (including Ranges and Cooktops) 0 10-25-2007 04:10 PM
Convection Oven wedofood Oven Repair (including Ranges and Cooktops) 0 08-14-2007 01:01 PM
