Appliance Repair Forum
-   Dryer Repair (http://forum.appliancepartspros.com/dryer-repair/)
-   -   dryer quit (http://forum.appliancepartspros.com/dryer-repair/124001-dryer-quit.html)
wd45gto 09-11-2010 09:01 PM
dryer quit
dryer quit working in middle of cycle now wont restart.has power and hit reset button,nothing. now what ?
denman 09-12-2010 03:42 AM
Here are your parts includes a wiring diagram
Replacement parts for MAYTAG PYET244AYW Dryer - Ele | AppliancePartsPros.com
I do not know what you mean by the "reset button", I did not know that this unit had one.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Be careful as 240 volts is lethal !!!
Also on a high probability is the thermal fuse, Item 5 in Section 4.
Unplug the unit, disconnect one side of it and measure it with a meter should be 0 ohms.
If it is blown you have to find out what caused it to go.
Note: that sometimes they do just blow on their own but changing it without checking other things is a gamble.
Check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on high and the thermostats cannot regulate it.
If the above is OK then you will also have to replace the hi-limit as it should have regulated the temperature so the fuse did not blow.
You still have to find out why it blew.
Check that the belt is OK.
Check the seals (drum etc) in the unit. The air is pulled over the heating coils, through the drum and pushed out the exhaust. So any large seal leak will pull in room air and the cycling thermostat on the blower will run the unit hot.
Check that the lint filter is not coated with fabric softener residue which greatly reduces air flow.
Check/clean your vent system.
Check/clean the blower wheel.
If all OK you may want to replace the cycling thermostat as it's contacts may not be opening (welded shut).
wd45gto 09-12-2010 06:15 AM
thank you ,guess ill be busy today
Fixajet190 03-11-2011 04:10 PM
Motor check maytag dryer Pyet244ayw
I got this dryer a maytag Pyet244ayw from a neighbor , he says it stopped working in mid cycle . It has not power cord but i did a few checks on thermostats and they check good . He says its the Motor. I removed it but before spending money on new one How do i check it to make sure it is motor?? Thanks for help
denman 03-12-2011 04:06 AM
The following may help
http://www.applianceaid.com/wp-motors.html
You could hook it up to a line cord and try it.
Wiring diagram in the parts shows connections 1 to 2 (purple to white wires)
I would try using resistance to check the windings first.
1 to 2 should measure a couple ohms.
I am assuming that you checked the thermostat (Fuse) (Item 5 in Section 4).
This is the only one that will effect the motor.
Also that you disconnected one side of it when measuring it as this prevents you from reading an alternate/parallel circuit path.
