Discuss
Kenmore Dryer Buzzer
 in
Dryer Repair
Kenmore Dryer Buzzer when it starts (a few minutes after start up) will not go off until end of cycle.
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Kenmore Dryer Buzzer
  #1 (permalink)
Old 09-28-2008, 11:19 AM
danule31018 danule31018 is offline
Junior Member
danule31018 is on a distinguished road
Default Kenmore Dryer Buzzer
Brand: Kenmore   Age: More than 10 years
Kenmore Dryer Buzzer when it starts (a few minutes after start up) will not go off until end of cycle. Purchased as matching set but I only have a reliable Washer Model Number (110 92273800) the Dryer Nu indicates it should be a washer (110 92274800) according to my research. Can I pull of buzzer lead wire without affecting other operations? Dan
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 09-28-2008, 12:39 PM
Zanshin Zanshin is offline
Member
Zanshin is on a distinguished road
Default
I would be curious to know WHY the buzzer is going off, maybe a timer or control issue, but I had a white westinghouse model that didnt have an on/off switch for the dryer, so I made an adjustment.
with the POWER OFF to the unit, get behind the dryer and start pulling the back panel off of the console assembly, should be like 6 to 8 screws, you are looking for a small black square it should have two wires going to it, pull one of them and tape it off and secure it out of the way.
Keep in mind some models require that buzzer to cycle the timer operation, so its going to be a "try it out and see", if the timer doesnt advance probally you know what you need to do
  #3 (permalink)
Old 09-28-2008, 04:44 PM
kayakcrzy kayakcrzy is offline
Senior Expert
APP Volunteer
kayakcrzy is on a distinguished road
Default
Replace the timer. Tom ApplianceEducator.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
buzzer corleone Dryer Repair 1 09-03-2008 02:47 PM
Dryer Buzzer aocasio Dryer Repair 2 01-14-2008 10:53 AM
buzzer doesn't stop! lennylon Dryer Repair 4 12-19-2007 06:22 AM
Buzzer and start button buzzing dryer Dryer Repair 2 12-16-2007 03:08 PM
Disconnect Maytag dryer buzzer jdswartz Dryer Repair 1 10-15-2007 08:21 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
