Discuss
Sparks from heater element
 in
Dryer Repair
I removed the back of the dryer to check for belt slippage and I noticed that the wires leading to
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Sparks from heater element
  #1 (permalink)
Old 09-28-2008, 10:12 AM
blibby blibby is offline
Junior Member
blibby is on a distinguished road
Default Sparks from heater element
Model Number: LE80xsn2   Brand: Whirlpool   Age: More than 10 years
I removed the back of the dryer to check for belt slippage and I noticed that the wires leading to the heater element are not insulated and there are small sparks sporadically. The sparks look like the burning of small particulates. I looked at the replacement part on this website and there is no insulation on the wires. Is this sparking normal? I am concerned about the fire possibility.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 09-28-2008, 12:42 PM
Zanshin Zanshin is offline
Member
Zanshin is on a distinguished road
Default
I would be concerned too the way you described this, what I "think" your seeing is what happens to dust as it hits the glowing red wire of the element, if you truly had a spark or short, your household breaker would have reset by now.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
replaced heater element still no heat collieen Dryer Repair 1 05-08-2008 09:45 AM
ge wsm2700wawww replacing heater element bobatjsk Dryer Repair 1 12-28-2007 06:12 PM
No voltage to lower heater element buzz Oven Repair (including Ranges and Cooktops) 2 12-19-2007 08:40 AM
Heater Element Disconnected MMW Dishwasher Repair 4 12-05-2007 06:59 AM
replacing heater element Roy T Dryer Repair 1 11-11-2007 08:59 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
