Discuss
NO Heat
 in
Dryer Repair
I changed the fuse and thermast. What else should I do?
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » NO Heat
  #1 (permalink)
Old 09-27-2008, 12:44 PM
rbrennan rbrennan is offline
Junior Member
rbrennan is on a distinguished road
Default NO Heat
Brand: Roper   Age: 1 - 5 years
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 09-27-2008, 02:15 PM
Zanshin Zanshin is offline
Member
Zanshin is on a distinguished road
Default
Why did you change the fuse and thermostat? do you have tools to test continuity? Its possible you have incorrect power supply to the dryer or the heater element is open, without a multi meter you won't be able to test your voltage, you can visibly inspect the element though,its just a long coil, like a toaster, if its broken, its bad.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer will not heat during timed drying; will heat for short time while auto drying mg13nj Dryer Repair 11 11-11-2008 04:50 PM
No Heat While Turning, Heat When Stopped thou msg2008 Dryer Repair 1 08-07-2008 06:08 AM
Heat but not drying, seems like heat is not blowing good Papa1 Dryer Repair 2 10-07-2007 11:11 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
