| » NO Heat |
Why did you change the fuse and thermostat? do you have tools to test continuity? Its possible you have incorrect power supply to the dryer or the heater element is open, without a multi meter you won't be able to test your voltage, you can visibly inspect the element though,its just a long coil, like a toaster, if its broken, its bad.
| Display Modes | |
| Dryer will not heat during timed drying; will heat for short time while auto drying | mg13nj | Dryer Repair | 11 | 11-11-2008 04:50 PM |
| No Heat While Turning, Heat When Stopped thou | msg2008 | Dryer Repair | 1 | 08-07-2008 06:08 AM |
| Heat but not drying, seems like heat is not blowing good | Papa1 | Dryer Repair | 2 | 10-07-2007 11:11 AM |
