Discuss
Repair of squeaky dryer
 in
Dryer Repair
I did some research and found an article saying that the most likely causes of a squeak are the front
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Repair of squeaky dryer
  #1 (permalink)
Old 09-09-2010, 12:36 PM
Junior Member
sbuckley@dtec.com is on a distinguished road
Default Repair of squeaky dryer
Model Number: DDE7500GAL   Brand: GE   Age: More than 10 years
I did some research and found an article saying that the most likely causes of a squeak are the front drum support glides and the rear drum support bearing. So I ordered replacements of both from AppliancePartsPros (order #1345780). My plan is to go ahead and replace both parts since I'll have the machine torn apart. Here are my questions:
1) The slide kit assembly came with one set (a pair) of glides. I thought that was all I would need - one glide for the right side of the drum and one slide for the left side. But after reading some other posts on this site it seems that some dryers have 4 glides at the front. Did I order correctly, or do I need to order an additional set of glides?
2) The article said that I'd probably need to replace the rear drum bearing, so that's all I ordered. But one of the posts on this site has a comment from a technician telling the person they'd need to order a bearing kit in order to do the bearing replacement job. The bearing I ordered and received was only a few dollars, but the bearing kit costs much more. Will the bearing that I received not do the trick, and instead I need to order a bearing kit? Or is the bearing that I received all that I'll need?
3) The bearing that came in the shipment included a note saying that in using this as a replacement bearing "you should remove and discard the one inch steel and fiber washers". Does this mean that I am supposed to replace those with new ones? Or does it mean that they are no longer necessary parts when you install this new bearing?
Thank you!
Ads By Google
Related Models
General Electric DDE7500GAL Electric dryer
General Electric DDE7500GBL Electric dryer
General Electric DDE7600RAL Electric dryer
General Electric DDE7606MAL Electric dryer
General Electric DDE7606MBL Electric dryer
General Electric DDE7606MCL Electric dryer
General Electric DDE7606MDL Electric dryer
General Electric DDE7608MAL Electric dryer
General Electric DDE7608MBL Electric dryer
General Electric DDE7608MCL Electric dryer
General Electric DDE7608MDL Electric dryer
General Electric DDE7900BBL Electric dryer
General Electric DDE7900GAL Electric dryer
General Electric DDE7900GBL Electric dryer
General Electric DDE7900GDL Electric dryer
General Electric DDE7900MAL Electric dryer
General Electric DDE7900MBL Electric dryer
General Electric DDE7900MCL Electric dryer
General Electric DDE7900MDL Electric dryer
General Electric DDE7900RAL
General Electric DDE7900RALAA Electric dryer
General Electric DDE7900RALWW Electric dryer
General Electric DDE7900SAL Electric dryer
General Electric DDE7900SBLAA Electric dryer
General Electric DDE7900SBLWW Electric dryer
General Electric DDE7905SBLAA Electric dryer
General Electric DDE7905SBLWW Electric dryer
General Electric DDE7906LAL Electric dryer
General Electric DDE7906RAL Electric dryer
General Electric DDE7907RAL Electric dryer
General Electric DDE7909RAL Electric dryer
General Electric DDE8000MAL Electric dryer
General Electric DDE8000MBL Electric dryer
General Electric DDE8100DAL Electric dryer
General Electric DDE8107MAL Electric dryer
General Electric DDE8108VHL Electric dryer
General Electric DDE8109VML Electric dryer
General Electric DDE8200BAC Electric dryer
General Electric DDE8200DAL Electric dryer
General Electric DDE8200GAL Electric dryer
General Electric DDE8200GBL Electric dryer
General Electric DDE8200GDL Electric dryer
General Electric DDE8200RAM Electric dryer
General Electric DDE8200RBM Electric dryer
General Electric DDE8200RCM Electric dryer
General Electric DDE8200RFM Electric dryer
General Electric DDE8200SAMAA Electric dryer
General Electric DDE8200SAMWW Electric dryer
General Electric DDE8200SBMAA Electric dryer
General Electric DDE8200SBMWW Electric dryer
General Electric DDE8500RAM Electric dryer
General Electric DDE8500RBM Electric dryer
General Electric DDE8500RCM Electric dryer
General Electric DDE8500RFM Electric dryer
General Electric DDE8500SAMAA Electric dryer
General Electric DDE8500SAMWH Electric dryer
General Electric DDE8500SAMWW Electric dryer
General Electric DDE8500SBMAA Electric dryer
General Electric DDE8500SBMWH Electric dryer
General Electric DDE8500SBMWW Electric dryer
General Electric DDE8505SAMAA Electric dryer
General Electric DDE8505SAMWW Electric dryer
General Electric DDE8505SBMAA Electric dryer
General Electric DDE8505SBMWW Electric dryer
General Electric DDE8506MAL Electric dryer
General Electric DDE8506MBL Electric dryer
General Electric DDE8508MAL Electric dryer
General Electric DDE8508MBL Electric dryer
General Electric DDE8509RCM
General Electric DDE8509RCMAA Electric dryer
General Electric DDE8509RCMWW Electric dryer
General Electric DDE8509RFMAA Electric dryer
General Electric DDE8509RFMWW Electric dryer
General Electric DDE9200BAC Electric dryer
General Electric DDE9200DAL Electric dryer
General Electric DDE9200GAL Electric dryer
General Electric DDE9200GBL Electric dryer
General Electric DDE9200GDL Electric dryer
General Electric DDE9300LAL Electric dryer
General Electric DDE9300LBL Electric dryer
General Electric DDE9500MAL Electric dryer
General Electric DDE9500MBL Electric dryer
General Electric DDE9500RAM Electric dryer
General Electric DDE9500RCM Electric dryer
General Electric DDE9500RFM Electric dryer
General Electric DDE9600MAL Electric dryer
General Electric DDE9600MBL Electric dryer
General Electric DDE9600RAM Electric dryer
General Electric DDE9600RCM
General Electric DDE9600RCMAA Electric dryer
General Electric DDE9600RCMWW Electric dryer
General Electric DDE9600RFMAA Electric dryer
General Electric DDE9600RFMWW Electric dryer
General Electric DDE9605SAMAA Electric dryer
General Electric DDE9605SAMWW Electric dryer
General Electric DDE9605SBMAA Electric dryer
General Electric DDE9605SBMWW Electric dryer
General Electric DDG4580GAL Gas dryer
General Electric DDG4580GCL Gas dryer
General Electric DDG4580GDL Gas dryer
General Electric DDG4580GEL Gas dryer
General Electric DDG5180MAL Gas dryer
General Electric DDG5180MBL Gas dryer
General Electric DDG5180MCL Gas dryer
General Electric DDG5180RAL
General Electric DDG5180RALWW Gas dryer
General Electric DDG5180RBL
General Electric DDG5180RBLWW Gas dryer
General Electric DDG5180RCL
General Electric DDG5180RCLWW Gas dryer
General Electric DDG5180SBLAA Gas dryer
General Electric DDG5180SBLWW Gas dryer
General Electric DDG5189VSL Gas dryer
General Electric DDG5189VTL Gas dryer
General Electric DDG5189VUL Gas dryer
General Electric DDG5287MAL Gas dryer
General Electric DDG5287MBL Gas dryer
General Electric DDG5380GAL Gas dryer
General Electric DDG5380GCL Gas dryer
General Electric DDG5380GDL Gas dryer
  #2 (permalink)
Old 09-09-2010, 03:50 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Thank you!
1) There is only one pair of glides in this dryer.
2) This bearing should be good enough. Lubricate the shaft with a small amount of any high temperature grease.
3) You don't need these washers anymore.
Here are the breakdown diagrams and Replacement parts for General Electric DDE7500GAL Electric dryer | AppliancePartsPros.com
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
squeaky dryer Fred Phillips Dryer Repair 0 06-16-2010 03:48 PM
Squeaky dryer Bill in Mass. Dryer Repair 1 11-13-2009 02:21 PM
squeaky dryer liang Dryer Repair 2 04-21-2009 06:27 PM
squeaky dryer swthrtaj Dryer Repair 1 12-12-2008 02:16 PM
Squeaky Dryer Eliz17 Dryer Repair 1 09-24-2007 02:34 PM
