Discuss
No Heat Blown Hi Thermal Cut Out X2
 in
Dryer Repair
I have replaced the hi-thermal cut out that has blown twice. Checked air path for obstructions......none found. Cleaned
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » No Heat Blown Hi Thermal Cut Out X2
  #1 (permalink)
Old 09-24-2008, 08:02 PM
jpmclaugh3 jpmclaugh3 is offline
Junior Member
jpmclaugh3 is on a distinguished road
Default No Heat Blown Hi Thermal Cut Out X2
Model Number: LER4624BQ@   Brand: Whirlpool   Age: More than 10 years
I have replaced the hi-thermal cut out that has blown twice. Checked air path for obstructions......none found. Cleaned lint screen, and entire assembly, and checked blower impeller housing. Blows hot air with good velocity without vent hose attatched. Will replace vent hose also. All other thermals checked with meter, none open. Am I good to go, or should there be something else to check before assuming it is now ok. Thanks
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 09-24-2008, 08:35 PM
libertyappl libertyappl is offline
Senior Expert
APP Volunteer
libertyappl is on a distinguished road
Default
Check your wiring for a short. Check the vent al the way to the outside.
Nat
__________________
-We don't have a fancy website but, we do have fast reliable service in South Central Missouri & do warranty work for Whirlpool, Estate, Maytag, Amana, Frigidaire, Gibson & more. We service most of the South Central Ozarks region. Send us an email at libertyapplservice@yahoo.com
We are also Ministers that do a weekly jail house ministry.
Rate Liberty Appliance Service on MyPros.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Blown Thermal Fuse Again jpoldo Dryer Repair 1 09-08-2008 05:06 PM
thermal fuse blown, gas dryer crazyman Dryer Repair 1 09-07-2008 03:28 PM
Thermal fuses and thermostat and elelment ok but element does not heat up baldhippie Dryer Repair 1 06-05-2008 03:04 AM
Whirlpool Thermal Fuse Blown gerardjuarez Dryer Repair 1 05-12-2008 07:58 PM
2nd blown thermal fuse??? Cari Dryer Repair 2 11-25-2007 05:54 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
