Discuss
Whirlpool Dryer
 in
Dryer Repair
I Just Installed A New Time Control In This Unit And It Will Not Turn The Dryer Off ( This Is
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Whirlpool Dryer
  #1 (permalink)
Old 09-24-2008, 06:41 PM
jct1953 jct1953 is offline
Junior Member
jct1953 is on a distinguished road
Default Whirlpool Dryer
Model Number: LE4440XWW0   Brand: Whirlpool   Age: More than 10 years
I Just Installed A New Time Control In This Unit And It Will Not Turn The Dryer Off ( This Is The Same Issue I Had With The Original Timer And The Reason I Replaced It ).... The Timer Does Not Move, I Set It For 10min Come Back In 20min And It Has Not Moved. Is There Something Else That Would Cause This To Happen??
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 09-24-2008, 06:46 PM
libertyappl libertyappl is offline
Senior Expert
APP Volunteer
libertyappl is on a distinguished road
Default
Does the dryer run and heat?
Check your door switch, if the door switch isn't functioning then you may get the same effect.
Nat
__________________
-We don't have a fancy website but, we do have fast reliable service in South Central Missouri & do warranty work for Whirlpool, Estate, Maytag, Amana, Frigidaire, Gibson & more. We service most of the South Central Ozarks region. Send us an email at libertyapplservice@yahoo.com
We are also Ministers that do a weekly jail house ministry.
Rate Liberty Appliance Service on MyPros.com
  #3 (permalink)
Old 09-24-2008, 07:15 PM
Junior Member
Default
The Dryer does run and heat... The timer just does not move to off position. Door switch appears to function OK; dryer will turn off if door is opened while running..
  #4 (permalink)
Old 09-24-2008, 08:15 PM
Senior Expert
APP Volunteer
Default
Did you follow the wiring to the timer?
Nat
__________________
  #5 (permalink)
Old 09-25-2008, 07:08 AM
Ronald Windham Ronald Windham is offline
Junior Member
Ronald Windham is on a distinguished road
Default
Quote:
Nat
Good morning, Nat.
I have the same issue as JCT1953 with my Maytag Model MDE7400 AYW SN 19729588CL. I ordered and installed PN 33002803. Exactly same symptons--runs and heats, but the dial does not advance nor turn off the dryer. Door switch is operating.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Need help with whirlpool dryer angalabov Dryer Repair 5 08-06-2008 06:14 PM
wHIRLPOOL dRYER NEEDS HELP WAYNE JAROSH Dryer Repair 2 07-31-2008 09:51 PM
Whirlpool Gas Dryer Mike B. Dryer Repair 0 12-09-2007 09:59 AM
Whirlpool Dryer IrmaE Dryer Repair 3 11-18-2007 12:05 AM
Estate Dryer by Whirlpool/Dryer running but no heat tsm11238 Dryer Repair 1 11-06-2007 11:47 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
