Discuss
Dryer repair
 in
Dryer Repair
My GE (electric) dryer makes a high pitched squeaking sound about 1 time per second. It sounds like it is
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer repair
  #1 (permalink)
Old 07-24-2007, 01:45 PM
Doitmyself Doitmyself is offline
Junior Member
Doitmyself is on a distinguished road
Default Dryer repair
Brand: GE   Age: 5 - 10 years
My GE (electric) dryer makes a high pitched squeaking sound about 1 time per second. It sounds like it is coming from a place near the back of the dryer, and I believe I need to replace the rear drum bearings.
Am I on the right track? My other problem is that I am not sure how to access the rear drum. Do I need to remove the 3 hex nuts inside the drum, to release it from the bearings?
Any suggestions would be welcome.
  #2 (permalink)
Old 07-26-2007, 09:44 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Default
Doitmyself
Pull the dryer from the wall. In the center of the rear panel you'll find a rectangle metal cover holding by two 5/16" screws. Behind this cover is the rear drum bearing. Put a few drops of a machine oil inside the bearing and it should stop the noise.
Good luck.
  #3 (permalink)
Old 07-27-2007, 02:13 PM
jdman jdman is offline
Member
jdman is on a distinguished road
Default
I find that lubericating only buys a little time. Not long before replacing it anyway
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Removing dryer cabinet to repair igniter Mikeofba Dryer Repair 1 07-27-2007 11:48 PM
