Kenmore dryer not heating
I recently ordered part #4391960 which is the Heating element. I need to know if I also need to order the dryer thermal fuse. Dryer does everything besides heat.
Quote:
Did you have any heat problems before this occurred ? If you had no heating problems, and you find that the element is broken and not shorted out, you will most likely not need a thermal fuse. If you have a test meter or light you can check the fuse for a closed(infinite) circuit. Good Luck, :) :) :) |
| All times are GMT -7. The time now is 04:35 PM. |
