Register | FAQ's | New Posts | Today's Posts | Extras |
» Whirlpool GEW9200LW0 clicks and senses, but nothing more |
![]() Model Number: GEW9200LW0 Brand: Whirlpool Age: 5 - 10 years
![]() My dryer makes a clicking sound and the front panel lights up as it should, but the sensing light stays on and it just stops. It will not turn or dry at all. I have tried to enter test mode to get an error code, but get no response to the routine that is supposed to let me into test mode. Please help. Frnak Related Models |
See inside of your appliance - diagrams and part photos for virtually every model.![]() powered by AppliancePartsPros.com |
![]() Perform the Test# 4 (step 4) as instructed in the Tech sheet. Post the results.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL GEW9200LW0 | AppliancePartsPros.com Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
![]() Thanks Gene. I was wrong. I got into the diagnostic mode and it passed all tests with giving any error code. Should I try to do the technician stuff in later tests? I will need to borrow the ohm meter or whatever it is to get this done.
Quote:
![]() Quote:
__________________
![]() Quote:
I have tried step 4 and the ohm meter shows infinity at p2 on the control board. I took the toe panel off and am trying to test the resistance on the cables, but I CANNOT disconnect the sensor from the wire harness to test it. I have used pliers and tried to the pull them apart. What is the trick? |
![]() According to the instructions, if the result of the test was infinity, you have to measure the resistance between pins 1 and 2 of the connector P2 on the machine control board. You don't have to go to the wire harness and the moister sensor.
In such situation I believe the problem is a bad machine control electronics. - The electronic control Part number: AP3604453 Gene.
__________________
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
Whirlpool compressor clicks, does not run. | 69blueray | Refrigerator & Freezer Repair | 5 | 07-02-2013 03:22 PM |
Need help with my GEW9200LW0 Dryer | heartlessmcfly | Dryer Repair | 1 | 03-26-2010 05:42 PM |
Whirlpool clicks on and off | Joe f | Refrigerator & Freezer Repair | 0 | 06-13-2008 09:48 AM |
