gshafer
#1 Posted : Tuesday, September 7, 2010 9:23:21 AM(UTC)
gshafer
I have a Roper REX3615we2 electric dryer, approximately 7 years old which will heat and dry clothes but will not shut off. I have recently replaced the high limit thermostat, the thermal cutoff, the thermal fuse as well as a new timer (ana thorough cleaning). I cna only assume I have installed something incorrectly or one of the new parts is bad. Does anyone have any other suggestions?
Thanks in advance for your help!
#2 Posted : Tuesday, September 7, 2010 1:39:45 PM(UTC)
Very likely the problem is a bad timer motor resistor. measure its resistance. It suppose to be close to 5000 Ohms. If this resistor is open , there is no power to the timer motor.
- The timer resistor Part number: AP3094277
gshafer
#3 Posted : Wednesday, September 8, 2010 4:51:23 AM(UTC)
gshafer
Thanks Gene, I will check the resistance. I did notice that the timer does move in the timed cycle, hower, although it stops moving when it reaches the 'off' setting and the dryer keeps running.
Dryer Heats But will not shut off (Dryer Repair)
by jomdlcrs 6/20/2011 12:26:18 PM(UTC)
