| » Electric dry runs no heat |
Model Number: CRER7900AS1 Brand: Frigidaire Age: 1 - 5 years
according to my troubleshooting for my problem the possible cause is one of the 2 house fuses have blown. The solution shows replae fuse. Ok so what the heck is the house fuse and where do you go to replace this.. I've been told that it may be a thermal fuse, but according to the person I spoke to there is no thermal fuse..
Turn your house breaker for the dryer, in your breaker box, off and then back on and see what it does.
Nat
__________________
-We don't have a fancy website but, we do have fast reliable service in South Central Missouri & do warranty work for Whirlpool, Estate, Maytag, Amana, Frigidaire, Gibson & more. We service most of the South Central Ozarks region. Send us an email at libertyapplservice@yahoo.com We are also Ministers that do a weekly jail house ministry. Rate Liberty Appliance Service on MyPros.com |
Remove the rear panel and check the thermostats(remove one set at a time) with an ohm meter, for continuity. Also check the element the same way.
nat
__________________
The fuse in this dryer will stop the motor from working. So if it still runs then you have a broken element:gibson rear wall.jpg
First remove the front panel: top removal.jpg
| Display Modes | |
| Electric dryer runs but no heat | tkoronis | Dryer Repair | 1 | 06-26-2008 06:38 AM |
| GE electric dryer runs, heats, won't shut off | carpenter | Dishwasher Repair | 2 | 04-29-2008 10:32 AM |
| roper electric dryer, runs, no heat | nathan1 | Dryer Repair | 1 | 03-07-2008 06:15 PM |
| gas-electric runs but not heat | martucha | Dryer Repair | 3 | 11-14-2007 10:31 PM |
| electric dryer has no heat, but still runs in both permanent press and timed dry. | chrisnross | Dryer Repair | 1 | 09-12-2007 06:51 AM |
