Discuss
Electric dry runs no heat
 in
Dryer Repair
according to my troubleshooting for my problem the possible cause is one of the 2 house fuses have blown. The
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Electric dry runs no heat
  #1 (permalink)
Old 09-23-2008, 10:10 AM
Katherine Schuler Katherine Schuler is offline
Junior Member
Katherine Schuler is on a distinguished road
Default Electric dry runs no heat
Model Number: CRER7900AS1   Brand: Frigidaire   Age: 1 - 5 years
according to my troubleshooting for my problem the possible cause is one of the 2 house fuses have blown. The solution shows replae fuse. Ok so what the heck is the house fuse and where do you go to replace this.. I've been told that it may be a thermal fuse, but according to the person I spoke to there is no thermal fuse..
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 09-23-2008, 01:30 PM
libertyappl libertyappl is offline
Senior Expert
APP Volunteer
libertyappl is on a distinguished road
Default
Turn your house breaker for the dryer, in your breaker box, off and then back on and see what it does.
Nat
__________________
-We don't have a fancy website but, we do have fast reliable service in South Central Missouri & do warranty work for Whirlpool, Estate, Maytag, Amana, Frigidaire, Gibson & more. We service most of the South Central Ozarks region. Send us an email at libertyapplservice@yahoo.com
We are also Ministers that do a weekly jail house ministry.
Rate Liberty Appliance Service on MyPros.com
  #3 (permalink)
Old 09-24-2008, 07:36 AM
Junior Member
Default
Yes I tryed that but still nothing. Whats next....
  #4 (permalink)
Old 09-24-2008, 09:13 AM
Senior Expert
APP Volunteer
Default
Remove the rear panel and check the thermostats(remove one set at a time) with an ohm meter, for continuity. Also check the element the same way.
nat
__________________
  #5 (permalink)
Old 09-24-2008, 04:21 PM
SublimeMasterJW SublimeMasterJW is offline
Senior Expert
APP Volunteer
SublimeMasterJW is on a distinguished road
Default Check it out:
The fuse in this dryer will stop the motor from working. So if it still runs then you have a broken element:gibson rear wall.jpg
  #6 (permalink)
Old 09-24-2008, 04:25 PM
Senior Expert
APP Volunteer
Default to gain access to the element you must...
First remove the front panel: top removal.jpg
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Electric dryer runs but no heat tkoronis Dryer Repair 1 06-26-2008 06:38 AM
GE electric dryer runs, heats, won't shut off carpenter Dishwasher Repair 2 04-29-2008 10:32 AM
roper electric dryer, runs, no heat nathan1 Dryer Repair 1 03-07-2008 06:15 PM
gas-electric runs but not heat martucha Dryer Repair 3 11-14-2007 10:31 PM
electric dryer has no heat, but still runs in both permanent press and timed dry. chrisnross Dryer Repair 1 09-12-2007 06:51 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
