| » Spins, no heat |
Model Number: 110.64992300 Brand: Kenmore Age: 1 - 5 years
I've checked the following for continuity:
Thermistor (highest reading at 9K Ohms, at 70 degrees) Heating coil 10.5 Ohms Thermistor Thermal fuse Thermal cut-off Power cord to inside control panel Outlet is 3 prong and tests 110 volts output on each pair. Your ideas will be greatly appreciated. Michael |
Test the element, thermal cutoffs and thermostat fix for continuity, without wire leads on. That will tell you which part(s) are bad.
Nat
__________________
-We don't have a fancy website but, we do have fast reliable service in South Central Missouri & do warranty work for Whirlpool, Estate, Maytag, Amana, Frigidaire, Gibson & more. We service most of the South Central Ozarks region. Send us an email at libertyapplservice@yahoo.com We are also Ministers that do a weekly jail house ministry. Rate Liberty Appliance Service on MyPros.com |
Nat, I appreciate your advice to check components with all wires disconnected, but that was how I checked them. I realize that some may not know to do it that way.
Iamigor, you are absolutely right! I checked the heater relay and, sure enough, it was open between all 4 terminals. Would it do any damage to any other components, if I swapped the heater relay with the motor relay (same parts) and held the on switch in, so loads of clothes can be dried, until a new part is obtained? Thanks again. Your excellent advice is greatly appreciated. |
| Display Modes | |
| Dryer spins but does not heat | pelon2008 | Dryer Repair | 3 | 09-21-2008 08:47 PM |
| agitator spins, tub does not | fredtucson | Washer Repair | 3 | 08-08-2008 03:28 AM |
| washer some what spins | kent pratt | Washer Repair | 0 | 03-02-2008 04:18 PM |
| drum spins but timer does not move and no heat | hojo55 | Dryer Repair | 1 | 02-27-2008 05:53 PM |
| roper gas dryer spins but no heat | relvis | Dryer Repair | 1 | 09-19-2007 10:47 PM |
