Discuss
Gas dryer issues, no flame!!!
 in
Dryer Repair
It appeared to be the same issue I have been reading alot about with other gas dryers. No flame, but
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Gas dryer issues, no flame!!!
  #1 (permalink)
Old 09-21-2008, 07:47 AM
xj1978 xj1978 is offline
Junior Member
xj1978 is on a distinguished road
Default Gas dryer issues, no flame!!!
Model Number: MDG6000BWW   Brand: Maytag   Age: 5 - 10 years
It appeared to be the same issue I have been reading alot about with other gas dryers. No flame, but the ignitor heats red hot. So I assummed it was the coils for the gas dryer valve where bad so I picked some up at my appliance store and replaced them, but still no flame??? What else could it be? Please help me diagnose what else could be wrong! Thanks.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 09-23-2008, 03:00 PM
Junior Member
Default
No help??? Anybody out there!
  #3 (permalink)
Old 09-23-2008, 04:18 PM
libertyappl libertyappl is offline
Senior Expert
APP Volunteer
libertyappl is on a distinguished road
Default
Check your ignitor, sometimes even when they glow red hot, they aren't hot enough to light. It could also be the valve itself.
Nat
__________________
-We don't have a fancy website but, we do have fast reliable service in South Central Missouri & do warranty work for Whirlpool, Estate, Maytag, Amana, Frigidaire, Gibson & more. We service most of the South Central Ozarks region. Send us an email at libertyapplservice@yahoo.com
We are also Ministers that do a weekly jail house ministry.
Rate Liberty Appliance Service on MyPros.com
  #4 (permalink)
Old 09-23-2008, 04:35 PM
Junior Member
Default
Took the valve off and made sure it wasn't plugged or dirty. It was slightly dirty so I cleaned it up. Put the valve back on and now it fires up but only for a short period (10 seconds) and shuts off. I got a new ignitor from my local appliance store to try and that has the same outcome. I also cleaned the flame sensors lens and that had no affect. Everything has continuity. Could the flame sensor be bad/weak and not keeping the gas valves open? The also gave me a new set of coils to try compared to my new ones I just installed, but no difference either. Any ideas?
  #5 (permalink)
Old 09-23-2008, 05:14 PM
Junior Member
Default
I am 99% sure I figured it out. The cycling thermostat tells the coils to shut off once the temp reaches a set temp. So I removed the cycling thermostat and jumpered the circuit to keep the thermostat circuit closed while the gas valve fired and continued to stay fired until I removed the jumper. This tells me the thermostat is weak or worn out. Sound right???
  #6 (permalink)
Old 09-23-2008, 08:27 PM
Senior Expert
APP Volunteer
Default
That sounds correct.
__________________
  #7 (permalink)
Old 12-04-2008, 02:51 PM
Friar Dryer Friar Dryer is offline
Junior Member
Friar Dryer is on a distinguished road
Default Was it the thermostat?
Hi. I was wondering if this fixed the problem. I have much the same issue. Just replaced the coils, and not sure how to check the valve. I have a pretty old GE dryer. How did this turn out?
  #8 (permalink)
Old 12-05-2008, 04:15 PM
Junior Member
Default
It actually ended up being the gas valve itself that was bad. I took the valve off to clean it when the dryer wasn't working. I put it back on and fired it up the dryer worked for a few hours. Replaced the valve and it has worked great for weeks now.
  #9 (permalink)
Old 12-06-2008, 09:04 AM
Senior Expert
APP Volunteer
Default
Glad you were able to fix it!
Nat
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Duet Dryer Issues KCDA Dryer Repair 5 07-23-2008 12:10 AM
Kenmore Dryer Issues dccmgb Dryer Repair 0 07-12-2008 09:46 AM
Timer Issues/Gas Dryer jbw11263 Dryer Repair 0 06-26-2008 08:13 AM
Whirlpol Gas Dryer no Heat issues kolohe Dryer Repair 11 05-21-2008 07:16 PM
Whirpool Dryer heating issues dbreg Dryer Repair 1 01-04-2008 03:24 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
