sallyrinas
#1 Posted : Saturday, September 4, 2010 4:15:56 PM(UTC)
sallyrinas
The dryer wont run every thing comes on but when you go to start it it won't work. (The taeh that came out say's it's a main thermal over load kit)
#2 Posted : Thursday, September 9, 2010 5:32:12 AM(UTC)
Replacement parts for WHIRLPOOL GEW9200LQ0 | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%203979300.pdf
This should help repair it.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/cdce3c10dcb5382285256aa20064beaa/$FILE/Duetdry.pdf
Sounds like a fancy way to say a thermal fuse (Item 59 in Section 3)
If you have a meter, unplug the unit, remove one wire from the fuse and check it. It should be 0 ohms. This is the safest way.
Jiggery Pokery method is.
Unplug the unit.
Remove both wires from the fuse, short them together and tape them up so they will not short to the frame.
Plug the unit in and give it a try.
If blown, replace the fuse ASAP as it is a critical safety device re: prevents lint fires which can turn into house fires.
Also clean/check your vent system and the blower as these are the most common causes of it blowing.
Also could be your belt is broken as this unit has a belt switch in the motor circuit.
Kenmore Elec. Dryer - 2 Thermal Fuses in 1 week (Dryer Repair)
by fatchops 8/29/2016 11:38:51 AM(UTC)
Whirlpool elec. dryer not drying (Dryer Repair)
by Don Akina 3/19/2015 8:34:45 AM(UTC)
GE Super Capacity Elec. Dryer Intermittent No Heat (Dryer Repair)
by FireFox1435 9/24/2014 1:02:47 PM(UTC)
elec. dryer suddenly quits (Dryer Repair)
by spaldini101 5/20/2014 9:51:36 AM(UTC)
Elec. Dryer Trips Circuit Breaker (Dryer Repair)
by MacKenrick 8/5/2012 2:03:28 PM(UTC)
LG Tromm Elec. Dryer is Dead. I need Help! (Dryer Repair)
by matt_a 4/1/2012 8:27:02 AM(UTC)
Maytag Atlantis Elec. Dryer squeeking (Dryer Repair)
by jimgordey01 8/11/2011 10:50:32 AM(UTC)
Elec. dryer will start for a second then stop/makes noises (Dryer Repair)
by daverslocombe@gmail.com 6/30/2011 10:18:33 AM(UTC)
Elec. Dryer contimues to run (Dryer Repair)
by m3a 1/22/2010 7:40:01 PM(UTC)
elec. dryer randomly heats (Dryer Repair)
by bkawilliamson 11/2/2009 7:11:13 AM(UTC)
Kenmore elec. dryer troubleshoot (Dryer Repair)
by rpack41 4/27/2009 1:54:14 PM(UTC)
Maytag Elec. Dryer Runs but won't heat (Dryer Repair)
by pacomt 12/31/2008 4:25:04 PM(UTC)
Elec. dryer has power - won't start. (Dryer Repair)
by kschu01 11/19/2008 2:25:19 PM(UTC)
