landon
#1 Posted : Friday, September 19, 2008 10:10:32 PM(UTC)
landon
My daughter's dryer stopped drying. The tub turns but there is no heat. I have removed the back cover but did not see anything that looked like it may be the problem. The heat element looks ok but have not checked it with a meter. I do not have a schematic so I would only be guessing what every thing is.
Any help as what to look for?
Thanks in advance.
iamigor5@yahoo.com
#2 Posted : Friday, September 19, 2008 11:33:39 PM(UTC)
iamigor5@yahoo.com
would need complete model and serial can be found on tag near door
landon
#3 Posted : Saturday, September 20, 2008 5:40:26 AM(UTC)
landon
Would this look like the complete model: 96561220 65612?
If this is not I will look again today and also get the serial.
iamigor5@yahoo.com
#4 Posted : Saturday, September 20, 2008 9:53:52 AM(UTC)
iamigor5@yahoo.com
first i would check the thermal fuse and thermostats and last the heater unplug these one at a time and check with ohm meter contunuity means good open means bad let us know if this helps
landon
#5 Posted : Saturday, September 20, 2008 8:16:30 PM(UTC)
landon
Thanks for the word. I did go back and checked the items above but was ok. I then checked the heating element with an ohm meter and found the problem. The reason I did not see this problem before it was under the metal plate that covers half of the coils. It looked like the metal plate in the center had cracked and deflected down on the coil and shorted out. Now she is looking for a new dryer as the heating element will probably be a little high for an older machine. The cheapest one I found was about 60 plus shipping.
Kenmore electric dryer model 110.68622700 (Dryer Repair)
by Guest 11/12/2023 6:47:37 PM(UTC)
Kenmore electric dryer won't stay running (Dryer Repair)
by steve37887 10/25/2019 4:52:25 AM(UTC)
Kenmore Electric dryer (Dryer Repair)
by scorpio012 1/21/2018 12:45:44 PM(UTC)
Kenmore Electric Dryer Won't Heat (Dryer Repair)
by ginakra 9/21/2017 11:03:29 AM(UTC)
Kenmore electric dryer (Dryer Repair)
by carpenter83 12/1/2016 3:23:22 PM(UTC)
Kenmore Electric Dryer (Dryer Repair)
by johnhb 9/30/2015 7:27:45 AM(UTC)
by johnhb 9/30/2015 7:27:43 AM(UTC)
Kenmore Electric Dryer Won't power up. (Dryer Repair)
by lamarc72 11/19/2013 9:30:31 AM(UTC)
Kenmore Electric Dryer Runs and No Heat (Dryer Repair)
by dadunn1960 3/15/2013 8:14:52 AM(UTC)
Kenmore Electric Dryer - drum hits the top of the dryer. (Dryer Repair)
by willow5000 2/14/2013 9:19:06 PM(UTC)
Kenmore Electric Dryer - Runs but no heat and timer not running (Dryer Repair)
by CapN 12/11/2012 5:31:31 AM(UTC)
Kenmore Electric Dryer cuts off after running 2/3 minutes (Dryer Repair)
by Robert Ferrell 10/14/2011 9:21:09 AM(UTC)
Kenmore ELectric dryer (Dryer Repair)
by Donnadryer 9/11/2011 3:56:16 PM(UTC)
Kenmore electric dryer starts and stops (Dryer Repair)
by missfixit1974 9/9/2011 12:59:29 PM(UTC)
Kenmore electric Dryer won't Tumble (Dryer Repair)
by ohmydryer 9/6/2011 2:09:46 PM(UTC)
