Discuss
Dryer won't heat
 in
Dryer Repair
I have replaced the heating element and the thermostat, dryer still will not heat. Vent is clean, will not throw
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer won't heat
  #1 (permalink)
Old 09-03-2010, 09:59 AM
Junior Member
slick154 is on a distinguished road
Default Dryer won't heat
Model Number: 11069812990   Brand: Kenmore   Age: 5 - 10 years
I have replaced the heating element and the thermostat, dryer still will not heat. Vent is clean, will not throw hot air, timer works ok. Not sure where to look next. Any help would be greatly appreciated. This is a electric dryer.
Ads By Google
Related Models
Kenmore 11070052990 GAS DRYER
Kenmore 11070052991 GAS DRYER
Kenmore 11070056990 GAS DRYER
Kenmore 11070056991 GAS DRYER
Kenmore 1107007100 KENMORE GAS DRYER
Kenmore 1107007110 KENMORE GAS DRYER
Kenmore 1107007200 KENMORE GAS DRYER
Kenmore 1107007210 KENMORE GAS DRYER
Kenmore 11070072990 GAS DRYER
Kenmore 11070072991 GAS DRYER
Kenmore 1107007400 KENMORE GAS DRYER
Kenmore 1107007401 KENMORE GAS DRYER
Kenmore 1107007500 KENMORE GAS DRYER
Kenmore 1107007501 KENMORE GAS DRYER
Kenmore 1107007502 KENMORE GAS DRYER
Kenmore 1107007510 KENMORE GAS DRYER
Kenmore 1107007520 KENMORE GAS DRYER
Kenmore 1107007521 KENMORE GAS DRYER
Kenmore 1107007600 KENMORE GAS DRYER
Kenmore 1107007601 KENMORE GAS DRYER
Kenmore 1107007700 KENMORE GAS DRYER
Kenmore 1107007701 KENMORE GAS DRYER
Kenmore 11071062000 GAS DRYER
Kenmore 11071064000 GAS DRYER
Kenmore 11071066000 GAS DRYER
Kenmore 1107107800 KENMORE GAS DRYER
Kenmore 1107107801 KENMORE GAS DRYER-AUGUST, 1971
Kenmore 1107107802 KENMORE GAS DRYER
Kenmore 1107107900 KENMORE GAS DRYER
Kenmore 11071082000 DRYER
Kenmore 11071084000 DRYER
Kenmore 11071086000 DRYER
Kenmore 1107108800 KENMORE ELECTRIC DRYER
Kenmore 1107108801 KENMORE ELECTRIC DRYER
Kenmore 1107108802 KENMORE ELECTRIC DRYER
Kenmore 1107108900 KENMORE ELECTRIC DRYER
Kenmore 11071092000 GAS DRYER
Kenmore 1107109500 KENMORE GAS WASHN DRYER
Kenmore 1107109700 KENMORE GAS WASHN DRYER
Kenmore 1107109710 KENMORE GAS WASHN DRYER-JUNE, 1971
Kenmore 1107109900 KENMORE GAS WASHN DRYER
Kenmore 1107109901 KENMORE GAS WASHN DRYER
Kenmore 1107109910 KENMORE GAS WASHN DRYER
Kenmore 1107110500 KENMORE ELECTRIC WASH N DRYER
Kenmore 1107110700 KENMORE ELECTRIC WASH N DRYER
Kenmore 1107110710 KENMORE ELECTRIC WASHN DRYER
Kenmore 1107110900 KENMORE ELECTRIC WASHN DRYER
Kenmore 1107110901 KENMORE ELECTRIC WASHN DRYER
Kenmore 1107110910 KENMORE ELECTRIC WASHN DRYER-JUNE, 1971
Kenmore 1107114030 KENMORE COIN-OPERATED AUTOMATIC WASHER
Kenmore 1107114031 KENMORE COIN-OPERATED AUTOMATIC WASHER
Kenmore 1107114033 KENMORE COIN-OPERATED AUTOMATIC WASHER
Kenmore 1107114034 KENMORE COIN-OPERATED AUTOMATIC WASHER
Kenmore 1107117800 KENMORE GAS DRYER
Kenmore 1107117801 KENMORE GAS DRYER
Kenmore 1107118800 KENMORE ELECTRIC DRYER
Kenmore 1107118801 KENMORE ELECTRIC DRYER
Kenmore 1107157710 KENMORE GAS DRYER
Kenmore 1107158710 KENMORE ELECTRIC DRYER
Kenmore 11071802000 GAS DRYER
Kenmore 11071802001 GAS DRYER
Kenmore 11071804000 GAS DRYER
Kenmore 11071804001 GAS DRYER
Kenmore 11071812000 GAS DRYER
Kenmore 11071812001 GAS DRYER
Kenmore 11071814000 GAS DRYER
Kenmore 11071814001 GAS DRYER
Kenmore 11072032100 GAS DRYER
Kenmore 11072036100 GAS DRYER
Kenmore 11072042100 GAS DRYER
Kenmore 11072052100 GAS DRYER
Kenmore 11072054100 GAS DRYER
Kenmore 11072056100 GAS DRYER
Kenmore 11072062100 GAS DRYER
Kenmore 11072062101 GAS DRYER
Kenmore 11072062102 GAS DRYER
Kenmore 11072064100 GAS DRYER
Kenmore 11072064101 GAS DRYER
Kenmore 11072064102 GAS DRYER
Kenmore 11072066100 GAS DRYER
Kenmore 11072066101 GAS DRYER
Kenmore 11072066102 GAS DRYER
Kenmore 1107207100 KENMORE GAS DRYER-NOVEMBER, 1971
Kenmore 1107207210 KENMORE GAS DRYER
Kenmore 1107207400 KENMORE GAS DRYER-MARCH, 1972
Kenmore 1107207610 KENMORE GAS DRYER-MARCH, 1972
Kenmore 1107207611 KENMORE GAS DRYER
Kenmore 1107207630 KENMORE GAS DRYER-JANUARY, 1972
Kenmore 1107207700 KENMORE GAS DRYER-NOVEMBER, 1971
Kenmore 1107207701 KENMORE GAS DRYER
Kenmore 1107207800 KENMORE GAS DRYER-JANUARY, 1972
Kenmore 1107207801 KENMORE GAS DRYER-JANUARY, 1972
Kenmore 11073012100 GAS DRYER
Kenmore 11073012101 GAS DRYER
Kenmore 11073012102 GAS DRYER
Kenmore 11073014100 GAS DRYER
Kenmore 11073014101 GAS DRYER
Kenmore 11073014102 GAS DRYER
Kenmore 11073022100 GAS DRYER
Kenmore 11073022101 GAS DRYER
Kenmore 11073022102 GAS DRYER
Kenmore 11073024100 GAS DRYER
Kenmore 11073024101 GAS DRYER
Kenmore 11073024102 GAS DRYER
Kenmore 11073032100 GAS DRYER
Kenmore 11073032101 GAS DRYER
Kenmore 11073032102 GAS DRYER
Kenmore 11073034100 GAS DRYER
Kenmore 11073034101 GAS DRYER
Kenmore 11073034102 GAS DRYER
Kenmore 11073036100 GAS DRYER
Kenmore 11073036101 GAS DRYER
Kenmore 11073036102 GAS DRYER
Kenmore 11073042100 GAS DRYER
Kenmore 11073042101 DRYER
Kenmore 11073042102 GAS DRYER
Kenmore 11073046100 GAS DRYER
Kenmore 11073046101 DRYER
Kenmore 11073046102 GAS DRYER
Kenmore 11073052100 GAS DRYER
  #2 (permalink)
Old 09-03-2010, 12:55 PM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
Quote:
Slick,
Did you check the breakers, make sure both breakers are reset ?
Are you sure you have at least 220 Volts at the outlet ?
Same voltage at the terminal block(where the power cord attaches to the machine) ?
Do you have the wiring diagram ?
I don't have one but could probably use or get a generic diagram if necessary.
the diagram is usually located in the control panel, or taped to the inside of the top, when you raise it.
Good Luck,
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Roper (Gas) Dryer heats up then heat goes off (still running, no heat) jtdesignsca Dryer Repair 3 01-17-2013 12:06 PM
Dryer stops after a few minutes with heat on - will run continuously with heat off somegeek Dryer Repair 0 05-27-2010 01:35 PM
Clothes dryer runs, but doest not heat (Dryer no heat yzhong Dryer Repair 5 10-29-2009 04:54 PM
Dryer will not heat. It tumbles and cycles but it will not emit any heat. agentsmith0505 Dryer Repair 0 10-14-2009 09:44 AM
Gas Dryer tumbles but won't heat. Timer does not move when dryer is started. NEAL AMES Dryer Repair 1 01-02-2009 06:40 PM
