Discuss
celvig
 in
Dryer Repair
MY DRYER HAS POWER TO IT BECAUSE I CAN HEAR THE TIMER WORKING. BUT WHEN I PUSH THE SWITCH TO
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » celvig
  #1 (permalink)
Old 09-17-2008, 07:52 PM
celvig celvig is offline
Junior Member
celvig is on a distinguished road
Default celvig
Model Number: LEQ8611LG0   Brand: Whirlpool   Age: Less than 1 year
MY DRYER HAS POWER TO IT BECAUSE I CAN HEAR THE TIMER WORKING. BUT WHEN I PUSH THE SWITCH TO TURN IT ON IT DOESN'T DO ANYTHING. i HAVE REPLACE THE PUSH SWITCH.
ANY HELP
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 09-17-2008, 07:59 PM
libertyappl libertyappl is offline
Senior Expert
APP Volunteer
libertyappl is on a distinguished road
Default
If your unit is less than a year old, you mayhave voided the warranty when replacing the part, unless you had a certified tech do it.
But on another note, the timer works of 120V not 240V.
Try this go to your breaker box, throw your dryer breaker off for about 10 seconds and throw it back on then try the dryer.
Nat
__________________
-We don't have a fancy website but, we do have fast reliable service in South Central Missouri & do warranty work for Whirlpool, Estate, Maytag, Amana, Frigidaire, Gibson & more. We service most of the South Central Ozarks region. Send us an email at libertyapplservice@yahoo.com
We are also Ministers that do a weekly jail house ministry.
Rate Liberty Appliance Service on MyPros.com
  #3 (permalink)
Old 09-17-2008, 08:03 PM
SublimeMasterJW SublimeMasterJW is offline
Senior Expert
APP Volunteer
SublimeMasterJW is on a distinguished road
Default That old fuse on the blower housing malfunction most likely is the probelma amigo
Check it out:a back of a dryer.jpg On the left side in the rear where that heated air is vented to the outside a fuse is located that looks like this:fuse 2.jpg This dude will blow if that filter housing has a blockage. Replacing it will not completely fix that problema ifn you fail to remove that filter housing and clean out that puppy.That fuse by the way is connected in line with the door safety switch. So when it blows it is just like you have opened the door, HENCE the timer and everythang else wurks because power is not killed to the terminal. That is why it has smaller wires than the pigtail. Confused yet?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
