| » Is this part faulty??? |
Model Number: 3RAWZ481EML3 Brand: Whirlpool Age: 1 - 5 years
Hi
I have the above listed dryer. It has decided not to work today. If you set it to a programme and press start and nothing – it just sits there. I was advised that it might be an open thermostat. After examining the dryer thermostats (after turning off the power, checking for live feed and ensuring on one could turn the supply on) by removing the front panel, I’ve got the following results: Two thermostats on the heater box: both appear to be closed circuit (have continuity) There are two thermostats on the dryer exhaust ducting: One is a straight in line one and that appears to be closed.(thermal fuse???) The other one is round and has four connectors on it. Two thicker wires (from heater?? And this part appears to be ok. The other part (inner and thinner wires) appears to be open circuit. (I think it had heater or something similar on it???)... written on it it was part number 3387137. Now my question is, is this party faulty ???? Also, if it is faulty, where can I get one? I've not manged to find any suppliers in the UK so far. Ads By Google Related Models |
First question.....Did you disconnect the wires from each of the thermostats prior to doing the continuity check?
2nd ?......... Did you check to make sure you have full power to the plug in? You should be able to get any of the parts needed from this site. Nat
__________________
-We don't have a fancy website but, we do have fast reliable service in South Central Missouri & do warranty work for Whirlpool, Estate, Maytag, Amana, Frigidaire, Gibson & more. We service most of the South Central Ozarks region. Send us an email at libertyapplservice@yahoo.com We are also Ministers that do a weekly jail house ministry. Rate Liberty Appliance Service on MyPros.com |
| Display Modes | |
| Faulty sensor? | ddcoons | Oven Repair (including Ranges and Cooktops) | 1 | 02-26-2010 03:36 AM |
| Faulty Switch? | mrvirta | Dishwasher Repair | 0 | 01-05-2010 08:09 AM |
| Faulty dashboard | ljramos | Dryer Repair | 3 | 11-15-2009 02:46 AM |
| Faulty Microwave | ningissey | Microwave Repair | 3 | 10-22-2008 05:01 AM |
| faulty lid switch | sanpablo7 | Washer Repair | 1 | 04-20-2008 06:35 PM |
