Discuss
Rattle on startup
 in
Dryer Repair
Our gas dryer makes a loud rattling sound in the back on startup that was not improved by changing the
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Rattle on startup
  #1 (permalink)
Old 09-20-2007, 06:25 PM
Junior Member
tillamook is on a distinguished road
Default Rattle on startup
Model Number: DG312   Brand: Maytag   Age: More than 10 years
Our gas dryer makes a loud rattling sound in the back on startup that was not improved by changing the drive belt. Once up to speed, it seems to be relatively quiet.
The motor seemed to turn ok by hand, but I wondered if it might have to do with the four guide wheels on the back wall. Any counsel would be appreciated. Thank you.
Ads By Google
Related Models
Maytag DG312 Dryer - Gas
Maytag DG312D Dryer - Gas
Maytag DG313 Dryer - Gas
Maytag DG313D Dryer - Gas
Maytag DG31CA Dryer - Gas
Maytag DG31CM Dryer - Gas
Maytag DG31CT Dryer - Gas
Amana DG3240 Washer - Top Loading
Amana DG3250 Washer - Top Loading
Amana DG3261 Washer - Top Loading
Amana DG3280 Washer - Top Loading
Amana DG3281 Washer - Top Loading
Amana DG3291 Washer - Top Loading
Maytag DG32CA Dryer - Gas
Maytag DG32CM Dryer - Gas
Maytag DG32CT Dryer - Gas
Amana DG3300 Washer - Top Loading
Amana DG3331 Washer - Top Loading
Amana DG3341 Washer - Top Loading
Amana DG3350 Washer - Top Loading
Maytag DG33CA Dryer - Gas
Maytag DG33CM Dryer - Gas
Maytag DG34CD Dryer - Gas
Maytag DG34CQ Dryer - Gas
Frigidaire DG350RXD1 Wwh(v2) / 27 " Gas Dryer
Frigidaire DG350RXD2 Wwh(v2) / 27 " Gas Dryer
Frigidaire DG350RXD3 Wwh(v1) / 27 " Gas Dryer
Frigidaire DG350RXW1 Wwh(v1) / 27 " Gas Dryer
Frigidaire DG350RXW2 Wwh(v1) / 27 " Gas Dryer
Frigidaire DG350RXW3 Wwh(v2) / 27 " Gas Dryer
Amana DG3630 Washer - Top Loading
Amana DG3680 Washer - Top Loading
Amana DG3681 Washer - Top Loading
Amana DG3800 Washer - Top Loading
Amana DG3801 Washer - Top Loading
Maytag DG382 Dryer - Gas
Amana DG3860 Washer - Top Loading
Amana DG3861 Washer - Top Loading
Frigidaire DG3900ADD1 Frg(v6) / 27 " Gas Dryer
Frigidaire DG3900AWW1 Frg(v5) / 27 " Gas Dryer
Maytag DG4000 Dryer - Gas
Frigidaire DG400AXD1 Wwh(v4) / 27 " Gas Dryer
Frigidaire DG400AXD2 Wwh(v4) / 27 " Gas Dryer
Frigidaire DG400AXW1 Wwh(v3) / 27 " Gas Dryer
Frigidaire DG400AXW2 Wwh(v3) / 27 " Gas Dryer
Frigidaire DG400EXD1 Wwh(v1) / Gas Dryer
Frigidaire DG400EXD4 Wwh(v2) / Gas Dryer
Frigidaire DG400EXD5 Wwh(v3) / Gas Dryer
Frigidaire DG400EXF1 Wwh(v4) / Gas Dryer
Frigidaire DG400EXF4 Wwh(v5) / Gas Dryer
Frigidaire DG400EXF5 Wwh(v6) / Gas Dryer
Frigidaire DG400EXH1 Wwh(v7) / Gas Dryer
Frigidaire DG400EXH4 Wwh(v8) / Gas Dryer
Frigidaire DG400EXH5 Wwh(v9) / Gas Dryer
Frigidaire DG400EXV1 Wwh(v10) / Gas Dryer
Frigidaire DG400EXV4 Wwh(v11) / Gas Dryer
Frigidaire DG400EXV5 Wwh(v12) / Gas Dryer
Frigidaire DG400EXW1 Wwh(v13) / Gas Dryer
Frigidaire DG400EXW4 Wwh(v14) / Gas Dryer
Frigidaire DG400EXW5 Wwh(v15) / Gas Dryer
Frigidaire DG400JXD1 Wwh(v1) / Gas Dryer
Frigidaire DG400JXF1 Wwh(v2) / Gas Dryer
Frigidaire DG400JXH1 Wwh(v3) / Gas Dryer
Frigidaire DG400JXV1 Wwh(v4) / Gas Dryer
Frigidaire DG400JXW1 Wwh(v5) / Gas Dryer
Frigidaire DG400KXD1 Wwh(v9) / Gas Dryer
Frigidaire DG400KXD2 Wwh(v9) / 27 " Gas Dryer
Frigidaire DG400KXD3 Wwh(v6) / 27 " Gas Dryer
Frigidaire DG400KXD4 Wwh(v6) / 27 " Gas Dryer
Frigidaire DG400KXD5 Wwh(v6) / 27 " Gas Dryer
Frigidaire DG400KXD6 Wwh(v4) / 27 " Gas Dryer
Frigidaire DG400KXH1 Wwh(v8) / Gas Dryer
Frigidaire DG400KXH2 Wwh(v8) / 27 " Gas Dryer
Frigidaire DG400KXH3 Wwh(v5) / 27 " Gas Dryer
Frigidaire DG400KXH4 Wwh(v5) / 27 " Gas Dryer
Frigidaire DG400KXH5 Wwh(v5) / 27 " Gas Dryer
Frigidaire DG400KXW1 Wwh(v7) / Gas Dryer
Frigidaire DG400KXW2 Wwh(v7) / 27 " Gas Dryer
Frigidaire DG400KXW3 Wwh(v4) / 27 " Gas Dryer
Frigidaire DG400KXW4 Wwh(v4) / 27 " Gas Dryer
Frigidaire DG400KXW5 Wwh(v4) / 27 " Gas Dryer
Frigidaire DG400KXW6 Wwh(v3) / 27 " Gas Dryer
Frigidaire DG400SXD1 Wwh(v2) / 27 " Gas Dryer
Frigidaire DG400SXW1 Wwh(v1) / 27 " Gas Dryer
Frigidaire DG400TXD0 Wwh(v1) / 27 " Gas Dryer
Frigidaire DG400TXD1 Wwh(v1) / 27 " Gas Dryer
Frigidaire DG400TXW0 Wwh(v2) / 27 " Gas Dryer
Frigidaire DG400TXW1 Wwh(v2) / 27 " Gas Dryer
Maytag DG406 Dryer - Gas
Maytag DG407 Dryer - Gas
Maytag DG408 Dryer - Gas
Maytag DG409 Dryer - Gas
Maytag DG410 Dryer - Gas
Maytag DG412 Dryer - Gas
Maytag DG412D Dryer - Gas
Maytag DG482 Dryer - Gas
Maytag DG482D Dryer - Gas
Maytag DG490 Dryer - Gas
Maytag DG490D Dryer - Gas
Maytag DG4910 Dryer - Gas
Maytag DG500 Dryer - Gas
Frigidaire DG500AXD5 Wwh(v4) / 27 " Gas Dryer
Frigidaire DG500AXD6 Wwh(v4) / 27 " Gas Dryer
Frigidaire DG500AXW5 Wwh(v3) / 27 " Gas Dryer
Frigidaire DG500AXW6 Wwh(v3) / 27 " Gas Dryer
Frigidaire DG500EXD1 Wwh(v16) / Gas Dryer
Frigidaire DG500EXD4 Wwh(v17) / Gas Dryer
Frigidaire DG500EXD5 Wwh(v18) / Gas Dryer
Frigidaire DG500EXF1 Wwh(v19) / Gas Dryer
Frigidaire DG500EXF4 Wwh(v20) / Gas Dryer
Frigidaire DG500EXF5 Wwh(v21) / Gas Dryer
Frigidaire DG500EXH1 Wwh(v22) / Gas Dryer
Frigidaire DG500EXH4 Wwh(v23) / Gas Dryer
Frigidaire DG500EXH5 Wwh(v24) / Gas Dryer
Frigidaire DG500EXV1 Wwh(v25) / Gas Dryer
Frigidaire DG500EXV4 Wwh(v26) / Gas Dryer
Frigidaire DG500EXV5 Wwh(v27) / Gas Dryer
Frigidaire DG500EXW1 Wwh(v28) / Gas Dryer
Frigidaire DG500EXW4 Wwh(v29) / Gas Dryer
Frigidaire DG500EXW5 Wwh(v30) / Gas Dryer
  #2 (permalink)
Old 09-20-2007, 07:12 PM
ApplianceJunk's Avatar
Senior Expert
APP Volunteer
ApplianceJunk is on a distinguished road
Default
Check your blower fan wheel. They strip out in the center and will then free wheel on the motor shaft.
Take the front of the dryer off so you can see the blower wheel. Give the fan wheel a spin by hand to see if it spins around on the motor shaft.
__________________
ApplianceJunk.com ~ DIY Appliance Repair Forum
  #3 (permalink)
Old 09-21-2007, 11:26 AM
Junior Member
Default
Thanks for the counsel, ApplianceJunk
  #4 (permalink)
Old 09-23-2007, 06:00 PM
Junior Member
Default
You were dead on, ApplianceJunk. That's what it was and thanks to JB Weld, it seems to be ok now. Thanks.
  #5 (permalink)
Old 09-23-2007, 06:01 PM
Senior Expert
APP Volunteer
Default
Glad to hear you got it repaired.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Ice Maker... Startup rixemailfl Refrigerator & Freezer Repair 0 12-13-2009 03:13 PM
valve stutter at startup tmriley Dishwasher Repair 0 08-07-2009 07:15 PM
rattle jersey mom Refrigerator & Freezer Repair 1 04-07-2009 05:07 PM
Fan rattle stevemyers Microwave Repair 0 03-25-2009 02:25 PM
Blows Fuse on Startup pcfucci Microwave Repair 0 01-04-2008 07:16 PM
