Discuss
Roper Dryer Heat issue
 in
Dryer Repair
I have a Roper Electric Dryer Model REX3514RQ1. Its about 5 years old. It runs fine but no heat. My
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Roper Dryer Heat issue
  #1 (permalink)
Old 08-30-2010, 01:58 PM
Junior Member
LouVillian is on a distinguished road
Default Roper Dryer Heat issue
Model Number: http://epsteinlouisvillelawyer.com/   Brand: Roper   Age: 1 - 5 years
I have a Roper Electric Dryer Model REX3514RQ1. Its about 5 years old. It runs fine but no heat. My guess is the heating element. I first checked the Fuse box to make sure both fuses were in the on position. Turned them off then back on to be safe. Took the back off the dryer and disconnected the High Limit Dryer Switch and ran a wire to each Unhooked wire to test that. The dryer still did not heat up while this was done. Have i tried everything? Is it more then likely the Heating Element? Is there a way to sure fire check the Heating element?
Thanks in adavance for any help!
Ads By Google
Related Models
Whirlpool HTW4300TQ0 Automatic Washer
Maytag HTW4300TQ0 Automatic Washer
Whirlpool HTW4400TQ0 Automatic Washer
Maytag HTW4400TQ0 Automatic Washer
Frigidaire HV1530B Gib(v1) / Range Vent Hood
Frigidaire HV1530W Gib(v1) / Range Vent Hood
Frigidaire HV1536B Gib(v1) / Range Vent Hood
Frigidaire HV1536W Gib(v1) / Range Vent Hood
Frigidaire HV2530B Gib(v1) / Range Vent Hood Downdraft
Frigidaire HV2536B Kel(v1) / Range Vent Hood Downdraft
Frigidaire HV2730B Frg(v1) / Range Vent Hood Downdraft
Frigidaire HV2736B Frg(v2) / Range Vent Hood Downdraft
Magic Chef HV30 Hood
Magic Chef HV303 Hood
Jenn-Air HV303 Hood
Frigidaire HV30M Frg(v4) / Range Vent Hood
Magic Chef HV36 Hood
Magic Chef HV363 Hood
Jenn-Air HV363 Hood
Maytag HV630CORT Gas Water Heater
Maytag HV630XORT Gas Water Heater
Maytag HV640CBRS Gas Water Heater
Maytag HV640CBRT Gas Water Heater
Maytag HV640COCT Gas Water Heater
Maytag HV640CORT Gas Water Heater
Maytag HV640XBRS Gas Water Heater
Maytag HV640XBRT Gas Water Heater
Maytag HV640XOCT Gas Water Heater
Maytag HV640XORT Gas Water Heater
Maytag HV650CBRT Gas Water Heater
Maytag HV650COCT Gas Water Heater
Maytag HV650CRRT Gas Water Heater
Maytag HV650XBRT Gas Water Heater
Maytag HV650XOCT Gas Water Heater
Maytag HV650XRRT Gas Water Heater
General Electric HVM1540DM1BB Counter top microwave
General Electric HVM1540DM1WW Counter top microwave
General Electric HVM1540LM1CS Counter top microwave
General Electric HVM1540SM1SS Counter top microwave
General Electric HVM1750DM1CC Counter top microwave
General Electric HVM1750DMBB01 Counter top microwave
General Electric HVM1750DMWW01 Counter top microwave
General Electric HVM1750SMSS01 Counter top microwave
Maytag HVN41240X Gas Water Heater
Maytag HVN41250X Gas Water Heater
Maytag HVN4930T Gas Water Heater
Maytag HVN4940S Gas Water Heater
Maytag HVN4940T Gas Water Heater
Maytag HVN4950T Gas Water Heater
Maytag HVN51240X Gas Water Heater
Maytag HVN51250X Gas Water Heater
Maytag HVN5930T Gas Water Heater
Maytag HVN5940S Gas Water Heater
Maytag HVN5940T Gas Water Heater
Maytag HVN5950T Gas Water Heater
Maytag HVP41240X Gas Water Heater
Maytag HVP41250X Gas Water Heater
Maytag HVP4930T Gas Water Heater
Maytag HVP4940S Gas Water Heater
Maytag HVP4940T Gas Water Heater
Maytag HVP4950T Gas Water Heater
Maytag HVP51240X Gas Water Heater
Maytag HVP51250X Gas Water Heater
Maytag HVP5930T Gas Water Heater
Maytag HVP5940S Gas Water Heater
Maytag HVP5940T Gas Water Heater
Maytag HVP5950T Gas Water Heater
Jenn-Air HW200 Hot Water Dispenser
Jenn-Air HW200B Hot Water Dispenser
Jenn-Air HW200W Hot Water Dispenser
Hoover HWA2000A Washer - Top Loading
Hoover HWA2000AA Washer - Top Loading
Hoover HWA2000AW Washer - Top Loading
Hoover HWA2000GA Washer - Top Loading
Hoover HWA2000GW Washer - Top Loading
Hoover HWA2000KA Washer - Top Loading
Hoover HWA2000KW Washer - Top Loading
Hoover HWA2000W Washer - Top Loading
Hoover HWA2006A Washer - Top Loading
Hoover HWA2006H Washer - Top Loading
Hoover HWA2006W Washer - Top Loading
Hoover HWA2501GA Washer - Top Loading
Hoover HWA2501GW Washer - Top Loading
Hoover HWA2506W Washer - Top Loading
Hoover HWA2507GV Washer - Top Loading
Hoover HWA2606A Washer - Top Loading
Hoover HWA2606W Washer - Top Loading
Amana HWR302 Range - S/c S/i Ddraft Gas
Amana HWR3021L Hood
Maytag HWR3021L  Hood
Amana HWR3021W Hood
Maytag HWR3021W  Hood
Amana HWR312 Range - S/c S/i Ddraft Gas
Amana HWR342 Range - S/c S/i Ddraft Gas
Amana HWR3421L Hood
Amana HWR3421W Hood
Amana HWR602 Range - S/c S/i Ddraft Gas
Amana HWR6021L Hood
Amana HWR6021W Hood
Amana HWR612 Range - S/c S/i Ddraft Gas
Amana HWR642 Range - S/c S/i Ddraft Gas
Amana HWR6421L Hood
Amana HWR6421W Hood
Maytag HX302ERTCSA Electric Water Heater
Maytag HX402ERSCSA Electric Water Heater
Maytag HX402ERTCSA Electric Water Heater
Maytag HX40NARS Gas Water Heater
Maytag HX40NARSCGA Gas Water Heater
Maytag HX40NART Gas Water Heater
Maytag HX40NARTCGA Gas Water Heater
Maytag HX40NARTD Gas Water Heater
Maytag HX40NARTW Gas Water Heater
Maytag HX40NQRT Gas Water Heater
Maytag HX40NQRT2 Gas Water Heater
Maytag HX40NQRT2CGA Gas Water Heater
Maytag HX40NQRTCGA Gas Water Heater
Maytag HX40PARS Gas Water Heater
Maytag HX40PARSCGA Gas Water Heater
Maytag HX40PART Gas Water Heater
Maytag HX40PARTCGA Gas Water Heater
  #2 (permalink)
Old 08-30-2010, 04:08 PM
Junior Member
Default
Pulled the Heating Element out and noticed the Bottom Coil is cracked in the middle. Im guessing this should correct my problem if replaced. If any techs can share some light it would be appreciated.
  #3 (permalink)
Old 08-31-2010, 02:40 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Not quite sure how you trouble shot it so I cannot say.
Yes
Yes, use a meter.
You did not include a model number so I cannot try to find a wiring diagram for you. Hopefully you have one.
Heating elements are usually 10 to 12 ohms approximately.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Roper (Gas) Dryer heats up then heat goes off (still running, no heat) jtdesignsca Dryer Repair 3 01-17-2013 12:06 PM
Issue with timer on Roper dryer res7745rq madcow43 Dryer Repair 1 08-31-2010 02:11 AM
dryer heat issue rvw67 Dryer Repair 0 05-06-2009 05:27 PM
GE Dryer-Heat issue iceman5cc5 Dryer Repair 1 03-25-2008 03:40 PM
Roper Dryer timer and heating issue Wing Commander Dryer Repair 1 11-20-2007 11:11 PM
