Appliance Repair Forum
-   Dryer Repair (http://forum.appliancepartspros.com/dryer-repair/)
-   -   Roper Dryer Heat issue (http://forum.appliancepartspros.com/dryer-repair/119930-roper-dryer-heat-issue.html)
LouVillian 08-30-2010 01:58 PM
I have a Roper Electric Dryer Model REX3514RQ1. Its about 5 years old. It runs fine but no heat. My guess is the heating element. I first checked the Fuse box to make sure both fuses were in the on position. Turned them off then back on to be safe. Took the back off the dryer and disconnected the High Limit Dryer Switch and ran a wire to each Unhooked wire to test that. The dryer still did not heat up while this was done. Have i tried everything? Is it more then likely the Heating Element? Is there a way to sure fire check the Heating element?
Thanks in adavance for any help!
LouVillian 08-30-2010 04:08 PM
Pulled the Heating Element out and noticed the Bottom Coil is cracked in the middle. Im guessing this should correct my problem if replaced. If any techs can share some light it would be appreciated.
denman 08-31-2010 02:40 AM
Not quite sure how you trouble shot it so I cannot say.
Yes
Yes, use a meter.
You did not include a model number so I cannot try to find a wiring diagram for you. Hopefully you have one.
Heating elements are usually 10 to 12 ohms approximately.
