| » squeakydryer |
Replacement parts for FRIGIDAIRE FEZ831AS1 Lc - Frigidaire | AppliancePartsPros.com Do I need to only replace the bearing? Yes that is the most common problem with this type of drum mounting. Could be it just needs cleaning and re-lubing with high temperature grease. Also when removing the rear cover (Item 6 in Section 1) be careful as the ball bearing (Item 5 in Section 1) likes to take off and hide once it is released. Other possibilities would be the front glides or the idler wheel
__________________
| Display Modes | |
