helenegp
#1 Posted : Monday, August 30, 2010 8:05:36 AM(UTC)
helenegp
My Kirkland dryer was slowly having a problem drying. It heated up, but took 3 or 4 cycles to dry completely. Now it has stopped drying.
On the parts list, I see several thermostats. Do I need them all, or just one? Please provide me with the part numbers I need to get this working again.
Thank you.:confused:
#2 Posted : Tuesday, August 31, 2010 12:56:10 AM(UTC)
Replacement parts for WHIRLPOOL SEDS800HQ0 | AppliancePartsPros.com
Here is the wiring diagram
http://www.servicematters.com/docs/wiring/Wiring%20Sheet%20-%203406687.pdf
It could be a number of things, just replacing parts without checking them will just cost you a lot of extra money so it is best to do more troubleshooting.
If by stopped drying you mean that the unit will not run at all then:
1. Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Red"]Be careful as 240 volts is lethal !!! [/COLOR]
2. Check the motor's thermal fuse (Item 7 in Section 3). It should be 0 ohms.
A jiggery pokery method is to unplug the unit, remove the wires from the fuse and short them together, tape them together so they cannot short to anything else. Plug it in and give it a try. If it now runs replace the fuse ASAP as this is a critical safety device to prevent lint/house fires.
3. Check the door switch and the push to start relay contacts.
If by not drying you mean it runs but has no heat:
1. Do step 1 from above.
2. Check the heating coil, should be approximately 10 ohms.
3. Check the heater's thermal fuse (Item 9 in Section 3).
If it is blown you have to find out what caused it to go.
Note: that sometimes they do just blow on their own but changing it without checking other things is a gamble. I beleive richappy (another regular poster on this forum) has done a study on thermostats and found a wide variation of actual trip point and what is specified.
Check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on high and the thermostats cannot regulate it.
If the above is OK then you will also have to replace the hi-limit as it should have regulated the temperature so the fuse did not blow.
You still have to find out why it blew.
Check that the belt is OK.
Check the seals (drum etc) in the unit. The air is pulled over the heating coils, through the drum and pushed out the exhaust. So any large seal leak will pull in room air and the cycling thermostat on the blower will run the unit hot.
Check that the lint filter is not coated with fabric softener residue which greatly reduces air flow.
Check/clean your vent system.
Check/clean the blower wheel.
If all OK you may want to replace the cycling thermostat as it's contacts may not be opening (welded shut).
4. If the fuse and heater are OK check the other thermostats in the heater circuit.
Since your problem started with long dry times you should also clean/check your vent system.
Also a good idea to give the interior a good cleaning, including the blower wheel.
Maytag MDG8400AWW gas dryer not drying clothes (Dryer Repair)
by tvr4 12/31/2023 2:45:43 PM(UTC)
Maytag Dryer not drying. Flame shuts off after 20-30 seconds (Dryer Repair)
by jbschwartz 6/27/2021 4:54:19 PM(UTC)
LG dryer not drying clothes (Dryer Repair)
by DGRA0005 7/6/2020 5:42:51 PM(UTC)
Whirlpool wed4800bq1 dryer not drying very good (Dryer Repair)
by t3i 3/19/2019 3:10:19 PM(UTC)
Dryer not drying (Dryer Repair)
by Scotty dog 12/3/2017 10:46:30 AM(UTC)
Dryer not Drying Clothes (Dryer Repair)
by Epfever1 12/1/2017 9:44:44 AM(UTC)
dryer not drying and water in drum (Dryer Repair)
by sonjawainwright 8/23/2017 8:07:12 AM(UTC)
Matag Dryer not drying in Intellidry Mode (Dryer Repair)
by themooser98 8/23/2017 5:43:28 AM(UTC)
maytag centennial electric dryer not drying/heating anymore (Dryer Repair)
by lloyd raymond martin 6/7/2017 5:34:16 PM(UTC)
Maytag Centennial Dryer not drying completely. (Dryer Repair)
by bryanakers 10/10/2016 5:42:01 AM(UTC)
My Dryer not drying (Dryer Repair)
by anikabrown 3/29/2016 3:57:03 AM(UTC)
Dryer not Drying (Dryer Repair)
by BraxLimbo 11/12/2015 11:08:58 PM(UTC)
Roper Dryer not drying (Dryer Repair)
by fhorta 11/3/2015 5:28:30 AM(UTC)
Samsung dryer not drying/get hot (Dryer Repair)
by Mommydearest819 5/30/2015 3:31:39 AM(UTC)
LG Tromm Dryer not drying (Dryer Repair)
by earcaesar 3/26/2015 5:50:26 PM(UTC)
