| » Dryer spins but does not heat |
Model Number: FDGB23RGS1 Brand: Frigidaire Age: 5 - 10 years
My Frigidaire Dryer does not heat. What could it be? The igniter or thermostat?
You have to check for continuity:
1. The igniter (#74 on the break down diagram) 2. The flame sensor (#79 on the break down diagram) 3. The high limit thermostat (#33 on the break down diagram) 4. The cycling thermostat (#15 on the break down diagram) Any part with open circuit has to be replaced. Here are the break down diagrams for the Frigidaire dryer Model FDGB23RGS1 Gene.
__________________
Professional appliance repair in Los Angeles, California. |
Both thermostats and sensor circuits are fine. Igniter showed nothing, so i bought a new igniter and the dryer still doesn't work. Check the circuit on the new igniter and it only registers up to 3. Looks like a faulty part.
Thanks for your input Gene. I think I might have to call someone now though. Need the thing fixed!!! |
I JUST FINISHED FIXING MY DRYER WHICH IS A KENMORE, IT HAD THE SAME PROBLEM. THE FIRST THING TO CHECK IS THE THERMAL FUSE,IF IT IS BLOWN YOUR IGNITER WILL NOT WORK. THE IGNITER IS WHAT TURNS THE GAS ON. TO CHECK THE FUSE YOU NEED A VOLT-OHM METER. CHECK FOR CONTINUITY TO SEE IF FUSE IS GOOD. PLEASE LET ME KNOW IF YOU NEED ANYMORE INFO. GEORGE E GEONDEE@ATT.NET
| Display Modes | |
| Dryer will not heat during timed drying; will heat for short time while auto drying | mg13nj | Dryer Repair | 11 | 11-11-2008 04:50 PM |
| washer some what spins | kent pratt | Washer Repair | 0 | 03-02-2008 04:18 PM |
| drum spins but timer does not move and no heat | hojo55 | Dryer Repair | 1 | 02-27-2008 05:53 PM |
| Estate Dryer by Whirlpool/Dryer running but no heat | tsm11238 | Dryer Repair | 1 | 11-06-2007 11:47 AM |
| roper gas dryer spins but no heat | relvis | Dryer Repair | 1 | 09-19-2007 10:47 PM |
