Discuss
Dryer heats only at start of cycle
 in
Dryer Repair
Gas dryer heats up initially when set on each of the three available temp settings then does not get hot
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer heats only at start of cycle
  #1 (permalink)
Old 09-15-2008, 08:57 AM
Junior Member
Dune5k is on a distinguished road
Default Dryer heats only at start of cycle
Model Number: ALG331RAW   Brand: Amana   Age: 5 - 10 years
Gas dryer heats up initially when set on each of the three available temp settings then does not get hot again regardless of cycle selection. Air flow is good and ducts are clean. I have printed out the diagrams and parts listings. After reading existing posts, it seems it might be a coil problem. The drawings and parts lists don't show coils separate from the gas valve assembly. Are they available separately? Is there something else I should check first? Any suggestions would be appreciated! Thanks!!
Related Models
Amana ALG331RAW DRYER- GAS
Amana ALG331RMC DRYER- GAS
Amana ALG331RMW DRYER- GAS
Amana ALG443RAC DRYER- GAS
Amana ALG443RAW DRYER- GAS
Amana ALG443RCW DRYER- GAS
Amana ALG565SAC DRYER- GAS
Amana ALG565SAW DRYER- GAS
Amana ALG643RAC DRYER- GAS
Amana ALG643RAW DRYER- GAS
Amana ALG643RBC DRYER- GAS
Amana ALG643RBW DRYER- GAS
Amana ALG643RMC WASHER-TOP LOADING
Amana ALG643RMC DRYER- GAS
Amana ALG643RMC1 WASHER-TOP LOADING
Amana ALG643RMW WASHER-TOP LOADING
Amana ALG643RMW DRYER- GAS
Amana ALG643RMW1 WASHER-TOP LOADING
Amana ALG665SAC DRYER- GAS
Amana ALG665SAW DRYER- GAS
Amana ALG866SAC DRYER- GAS
Amana ALG866SAW DRYER- GAS
Amana ALG866SBC DRYER- GAS
Amana ALG866SBW DRYER- GAS
Amana ALG866SCW DRYER- GAS
Amana ALG868QAW DRYER- GAS
Amana ALG868QCW WASHER-TOP LOADING
Amana ALG956EAC DRYER- GAS
Amana ALG956EAW DRYER- GAS
Whirlpool ALJ00520 Air-conditioner/heat pump
Whirlpool ALJ07520 Air-conditioner/heat pump
Whirlpool ALJ10020 Air-conditioner/heat pump
Whirlpool ALJ12020 Air-conditioner/heat pump
Whirlpool ALJ18040 Air-conditioner/heat pump
General Electric ALM15DAM1 Room air conditioner
General Electric ALM18DAM1 Zoneline
Admiral ALR1100AJQ RANGE- F/S STD GAS
Admiral ALR1100AJW RANGE- F/S STD GAS
Admiral ALR1420BDQ RANGE- F/S STD GAS
Admiral ALR1420BDW RANGE- F/S STD GAS
Admiral ALR1450AJW RANGE- F/S STD GAS
Admiral ALR1450BJW RANGE- F/S STD GAS
Admiral ALR5715QDS RANGE- S/C F/S GAS
Admiral ALR5715QDW RANGE- S/C F/S GAS
Amana ALW110RAW WASHER-TOP LOADING
Amana ALW210RAW WASHER-TOP LOADING
Amana ALW210RMC Washer - Top Loading
Amana ALW210RMC WASHER-TOP LOADING
Amana ALW210RMW Washer - Top Loading
Amana ALW210RMW WASHER-TOP LOADING
Admiral ALW221RJW WASHER-TOP LOADING
Amana ALW410DAW WASHER-TOP LOADING
Amana ALW430RAC WASHER-TOP LOADING
Amana ALW430RAW WASHER-TOP LOADING
Amana ALW432RAW WASHER-TOP LOADING
Amana ALW450QAC WASHER-TOP LOADING
Amana ALW450QAW WASHER-TOP LOADING
Amana ALW480DAC WASHER-TOP LOADING
Amana ALW480DAW WASHER-TOP LOADING
Amana ALW540RAC WASHER-TOP LOADING
Amana ALW540RAW WASHER-TOP LOADING
Amana ALW540RMC Washer - Top Loading
Amana ALW540RMC WASHER-TOP LOADING
Amana ALW540RMW Washer - Top Loading
Amana ALW540RMW WASHER-TOP LOADING
Amana ALW680RAC WASHER-TOP LOADING
Amana ALW680RAW WASHER-TOP LOADING
Amana ALW780QAC WASHER-TOP LOADING
Amana ALW780QAW WASHER-TOP LOADING
Amana ALW780QMC Washer - Top Loading
Amana ALW780QMC WASHER-TOP LOADING
Amana ALW780QMW Washer - Top Loading
Amana ALW780QMW WASHER-TOP LOADING
Amana ALW880QAC WASHER-TOP LOADING
Amana ALW880QAC1 WASHER-TOP LOADING
Amana ALW880QAW WASHER-TOP LOADING
  #2 (permalink)
Old 09-15-2008, 09:54 AM
Senior Expert
APP Volunteer
fixtec90 is on a distinguished road
Default
Your gas solenoids (coils) are most likely your problem. They are available separately. There are two, a primary and secondary coil, replace both.
  #3 (permalink)
Old 09-15-2008, 10:00 AM
Junior Member
Default
Thanks for the response. Any idea what the part number would be?
  #4 (permalink)
Old 09-15-2008, 10:45 AM
Senior Expert
APP Volunteer
Default
12001349 this is it.
  #5 (permalink)
Old 09-15-2008, 05:02 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You also can find it here: AP2150379 and you can have them next day.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #6 (permalink)
Old 09-19-2008, 01:24 PM
Junior Member
Default
Replaced the gas solenoids and it works fine again. Thanks for the help!!!!
  #7 (permalink)
Old 09-19-2008, 07:28 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
We're glad you were able to fix it.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
ge gas dryer heats once at beginning of cycle fish4800 Dryer Repair 0 07-28-2009 01:25 PM
dryer heats then stops before cycle ends ted burke Dryer Repair 1 06-17-2009 09:41 PM
Dryer only heats at start of cycle kdhb1@msn.com Dryer Repair 5 04-09-2009 03:22 PM
Maytag Gas Dryer Heats One Cycle glassbender Dryer Repair 3 02-13-2009 05:08 AM
Dryer heats thru first cycle, then no more sharkster Dryer Repair 3 07-30-2008 06:11 PM
