Discuss
Dryer not heating
 in
Dryer Repair
FROMBYU If you check,when the timer call,s for heat the contact is closed.The current goes down the
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer not heating
  #11 (permalink)
Old 09-16-2008, 03:48 PM
abbie abbie is offline
Senior Expert
APP Volunteer
abbie is on a distinguished road
Default
FROMBYU If you check,when the timer call,s for heat the contact is closed.The current goes down the red wire from the timer to the thermal cut off.It leaves there through the red/white down to the operating thermostat.The operating thermostat is closed ,the current passes through the operating stat which is then a red wire,down to the high limit thermostat which is closed, then through the element.That,s 1 side of the 240 volts.The other red wire going to the element is the other side of the 240 coming from the main thermal block. The common is the white/black on the high limit this completes the circuit.
__________________
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #12 (permalink)
Old 09-16-2008, 04:10 PM
libertyappl libertyappl is offline
Senior Expert
APP Volunteer
libertyappl is on a distinguished road
Default
Follow the directions (I do recommend getting the correct parts) I'm not sure what those are for, but it's not a Whirlpool!
The "To Harness" is talking about the wire harness.
Nat
__________________
-We don't have a fancy website but, we do have fast reliable service in South Central Missouri & do warranty work for Whirlpool, Estate, Maytag, Amana, Frigidaire, Gibson & more. We service most of the South Central Ozarks region. Send us an email at libertyapplservice@yahoo.com
We are also Ministers that do a weekly jail house ministry.
Rate Liberty Appliance Service on MyPros.com
  #13 (permalink)
Old 09-17-2008, 10:27 PM
frombyu frombyu is offline
Junior Member
frombyu is on a distinguished road
Default
Hi Nat,
Ok, so I did just like the part manual said - got a jumper wire, and connected the free coil terminal with the thermal cut off (correct if i am wrong) (where red wire connects)
Now the coil is glowing red all the time, even on Wrinkle Guard setting, when it should be no heat. What did I do wrong?
And also, on the picture with burned area, is that correct part used? it really looks like it should be something with two screws, not one...
  #14 (permalink)
Old 09-17-2008, 10:32 PM
Senior Expert
APP Volunteer
Default
That's what I was saying before those aren't the correct thermostats for your dryer, it comes in a kit part number 279816 which is both of the thermostats on the element housing.
Nat
__________________
  #15 (permalink)
Old 09-17-2008, 10:36 PM
Senior Expert
APP Volunteer
Default
Look at this post Sublimemaster posted a picture of the parts you should have.
dryer has no heat
Nat
__________________
  #16 (permalink)
Old 09-18-2008, 09:06 AM
Junior Member
Default
Ordered kit 279816, will post more when I install. But what concerns me is the Wrinkle Guard setting - and how the coil was on. I wonder if the coil now is wired to be on every time when the motor runs... But I'll post more after I get the kit.
Thank you.
  #17 (permalink)
Old 09-18-2008, 09:41 AM
Senior Expert
APP Volunteer
Default
It's more likely the incorrect thermostats that were put in. If you need a complete wiring diagram to check all the wires I can probably locate one.
Nat
__________________
  #18 (permalink)
Old 09-23-2008, 07:19 PM
Junior Member
Default
Hi again... So I installed the kit, and I referred to Replacing 279816 thermal cutoff kit (page 2)post. I still have the problem that on any setting the coil glows... Fluff air, Wrinkle Guard - manual says there is no neat on those settings. I connected black/white wire to jumper wire, so now jumper wire connects the High Limit thermostat terminal #1, and the coil. on the other side of the thermostat there is a red wire now. I tried switching them - no difference.
  #19 (permalink)
Old 09-23-2008, 08:05 PM
Junior Member
Default Picture
That's what it looks like now...
  #20 (permalink)
Old 09-23-2008, 08:11 PM
Senior Expert
APP Volunteer
Default
Where did you get that part? It is wired correctly. Although that still doesn't look like kit # 279816.....
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer not heating danceilike Dryer Repair 0 09-08-2008 02:32 PM
Dryer not heating maruca Dryer Repair 1 04-07-2008 08:54 AM
gas dryer not heating jakelexie Dryer Repair 1 01-25-2008 04:51 PM
Dryer not heating Jackie Dryer Repair 4 07-27-2007 11:05 AM
dryer not heating vonryansexp Dryer Repair 0 07-24-2007 12:01 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
