Discuss
Poor Drying/Heater Element Good
 in
Dryer Repair
Dryer works poorly in both timed dry and automatic Observed Heating element with front panel removed. Heated up to cherry
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Poor Drying/Heater Element Good
  #1 (permalink)
Old 09-12-2008, 06:44 AM
llorrachome27 llorrachome27 is offline
Junior Member
llorrachome27 is on a distinguished road
Default Poor Drying/Heater Element Good
Model Number: DE412   Brand: Maytag   Age: 5 - 10 years
Observed Heating element with front panel removed. Heated up to cherry red, then cycled off. After delay (long?) came back on.
Tried without any vent hose connected to remove any possible vent issues. Still poor perfromance. There are three thermostats
One heating element enclosure, two on exhaust vent after the blower. Any ideas?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 09-12-2008, 07:55 AM
libertyappl libertyappl is offline
Senior Expert
APP Volunteer
libertyappl is on a distinguished road
Default
If you have an ohm meter test all the thermostats for continuity, sounds like one of those maybe out. Make sure to remove the wires off the one being tested then put them back on, that way no wires get miss placed.
Post your results.
Nat
__________________
-We don't have a fancy website but, we do have fast reliable service in South Central Missouri & do warranty work for Whirlpool, Estate, Maytag, Amana, Frigidaire, Gibson & more. We service most of the South Central Ozarks region. Send us an email at libertyapplservice@yahoo.com
We are also Ministers that do a weekly jail house ministry.
Rate Liberty Appliance Service on MyPros.com
  #3 (permalink)
Old 09-15-2008, 06:37 AM
Junior Member
Default Thermostats
Tested all three thermostats. All read low ohms (good). Performed voltage checks while operating dryer with front back on by leading the multi-meter leads between the case and the front. Simultaneously, monitored exhaust temps. Exhaust temps cycled between ~160°F and ~123°F. Voltages went from 113 while heating to 124 while cooling. This was the same regardless of which mode it was operating in (permanent press or regular). After closer inspection of the thermostats, saw they may have the same temperature parameters (assuming I'm reading them right)
Thermostats
Heating Coil:
202564
T-O-D 60T21
3-03396
6837
L-200-20F
Permanent Press exhaust
203371
T-O-D 60T13
L140-20F
Regular Exhaust
611015
T-O-D 60T19
9807
L140-20F
Since I just picked this up from a rental unit, believe someone may have replaced thermostat with wrong one.
Also, what is the correct way should be reading voltages in a 220 Device? (L1/L2/Neutral or Ground as second lead)?
  #4 (permalink)
Old 09-15-2008, 08:59 AM
Senior Expert
APP Volunteer
Default
Between the L1 & neutral shoud be about 120V and the same with L2 & neutral between L1 & L2 should be 240V a 10% varience is allowed.
If you remove each set of wires off the thermostats you should be testing for continuity, If one of those doesn't have continuity then that's the bad one.
By looking at the thermostats I do think that this unit has the incorrect parts installed on it. If needed I can give you the part numbers.
Nat
__________________
  #5 (permalink)
Old 10-05-2008, 05:59 AM
Junior Member
Default
Replaced regular exhaust themostat, cleaned house exhaust duct for good measure. Works like a champ. Thanks.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Dryer not drying good hmfary1 Dryer Repair 1 02-12-2008 08:58 PM
Dishwasher not heating (element/thermostat good) jkordzi Dishwasher Repair 2 01-20-2008 07:03 PM
No bake, element appears good jreynolds Oven Repair (including Ranges and Cooktops) 5 12-21-2007 12:21 PM
Heater Element Disconnected MMW Dishwasher Repair 4 12-05-2007 06:59 AM
Heat but not drying, seems like heat is not blowing good Papa1 Dryer Repair 2 10-07-2007 11:11 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
