Discuss
Roper Dryer not working at all now
 in
Dryer Repair
Hello, I replaced the thermal fuse kit and thermostat because the dryer was working, but not heating. After i replaced
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Roper Dryer not working at all now
  #1 (permalink)
Old 09-19-2007, 02:32 PM
cpego123 cpego123 is offline
Junior Member
cpego123 is on a distinguished road
Default Roper Dryer not working at all now
Model Number: REX3614KW   Brand: Roper   Age: Less than 1 year
Hello,
I replaced the thermal fuse kit and thermostat because the dryer was working, but not heating. After i replaced the parts, it worked beautifully for about 5 minutes, then it shut off and will not turn back on. I tried replacing them again, but it still will not work. any idea what the problem might be?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 09-19-2007, 05:33 PM
dmicare dmicare is offline
Junior Member
dmicare is on a distinguished road
Default
Check for any lint clogs. clean & vacuum all ducts & ducts on the dryer.That is probably your issue.
Unless you get plenty of airflow the thermal fuse will not last
  #3 (permalink)
Old 09-19-2007, 06:46 PM
Junior Member
Default
Nope, that's not the problem. I checked it and it still isnt working.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
roper gas oven Kswick313 Oven Repair (including Ranges and Cooktops) 3 12-19-2007 06:42 AM
Kenmore Dryer Stopped Working Rob Dryer Repair 4 09-19-2007 08:23 PM
Roper Refridgarator picosa52 Refrigerator & Freezer Repair 2 09-10-2007 06:18 AM
Roper range Carol Oven Repair (including Ranges and Cooktops) 0 08-22-2007 02:22 PM
Roper dryer - 95 volts on timer motor jazbird1 Dryer Repair 1 08-10-2007 09:49 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
