Discuss
dryer motor wire diagram
 in
Dryer Repair
took wires loose on dryer motor to find out where short was dont remember where the wires hook back up
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » dryer motor wire diagram
  #1 (permalink)
Old 09-19-2007, 01:49 PM
loweluckie loweluckie is offline
Junior Member
loweluckie is on a distinguished road
Exclamation dryer motor wire diagram
Model Number: lt7000xtw0   Brand: Whirlpool   Age: 5 - 10 years
took wires loose on dryer motor to find out where short was dont remember where the wires hook back up please help me by telling me where the wires go thanks
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 09-19-2007, 07:23 PM
Matt / APP Team Matt / APP Team is offline
Administrator
APP Team
Matt / APP Team is on a distinguished road
Default
Look on the machine inside the console for the wiring diagram, it should be there on the machine unless someone tossed it. If you cant find it contact us with your email and Ill see if we can email it to you. Always write down or take a picture so you remember where everything goes.
__________________
Those who don't learn from history are doomed to relive it!
  #3 (permalink)
Old 09-21-2007, 05:36 AM
Junior Member
Default dryer motor diagram
it isnt on the inside of the machine
  #4 (permalink)
Old 09-22-2007, 09:16 PM
Junior Member
Default
no diagram inside
  #5 (permalink)
Old 09-23-2007, 05:23 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
You model # comes up as a washer!
__________________
  #6 (permalink)
Old 09-23-2007, 08:08 PM
Junior Member
Default
it is a combo but the model # on dryer motor is s58nxlht-6295 and the part # is 3391898 unit model # lt7000xtw0 serial # mx3716255 and stock # lt7000t
  #7 (permalink)
Old 09-24-2007, 03:46 AM
Senior Expert
APP Volunteer
Default
Can't find a schematic for your dryer, but will give you wiring ifo.
The heater wires are a larger gauge and usually red, these two go to pins 1& 2 of the motor, no polarity required. The blue wire goes to pin 5, the white/red wire goes to pin 4, and the black wire goes to pin 6. Your centrifical switch should have the wire tabs color coded, unless the label fell off.
If you scrambled the wires going to the motor windings from the centrifical switch, I can look that up later.
__________________
  #8 (permalink)
Old 11-17-2007, 09:56 PM
sdemiss sdemiss is offline
Junior Member
sdemiss is on a distinguished road
Question demis
I have a similar problem with wiring. I have a Kenmore Elite Dryer (Model# 110.73952102) and am trying to replace the electronic panel because one of the resistors is fried. I also opened the kick plate to clean a little bit and found a loose red/yellow wire that originates from the moisture sensor @ the electonic panel. Is this something that should be grounded, meaning be left like that, or should it be attached to something?
  #9 (permalink)
Old 02-10-2008, 11:43 PM
stretch88 stretch88 is offline
Junior Member
stretch88 is on a distinguished road
Question Just double checking about the wiring info for whirlpool dryer
Hey richappy. I am not trying to step on anyones toes, but you said that the white wire goes to pin #4, blue to #5, aren't those two swithched around? Every diagram and motor I am now checking on have blue at pin 4 and white w/red or orange stripe going to pin 5, and as you stated black at pin 6. Just checking. Take care and good luck. I hope to see which way is right. Thanks for all your knowledge, awesome sight.
Jamie
  #10 (permalink)
Old 01-06-2009, 09:35 AM
feisty63 feisty63 is offline
Junior Member
feisty63 is on a distinguished road
Default IF REPLACING DRYER MOTOR with universial motor how is the diagram going to help you?
IF REPLACING DRYER MOTOR with universial motor how is the diagram in the back panel wiring going to help you? your still in same boat. i need help with mine anybody know anything??
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer Timer Wire problem deleriousone Dryer Repair 17 08-06-2008 02:21 PM
Need help reading parts diagram for Magic Chef Refrigerator. alyaska 828 Refrigerator & Freezer Repair 0 09-07-2007 06:22 AM
Dryer motor R&R Pete Dryer Repair 0 08-14-2007 01:38 PM
Part not exactly like in diagram Anson Refrigerator & Freezer Repair 2 07-28-2007 08:59 AM
Dryer motor is noisey and sometimes humms and doesn't start Tudeman Dryer Repair 2 07-20-2007 04:20 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
