Discuss
Loud squeaking dryer
 in
Dryer Repair
Our dryer has suddenly developed a loud squeaking sound that will not quit. It dries the clothes fine and there
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Loud squeaking dryer
  #1 (permalink)
Old 08-21-2010, 09:19 PM
Junior Member
slballard is on a distinguished road
Red face Loud squeaking dryer
Model Number: MDE5500AYW   Brand: Maytag   Age: 5 - 10 years
Our dryer has suddenly developed a loud squeaking sound that will not quit. It dries the clothes fine and there is no vibration. How do I get to the drum and what parts would you recommend. It sounds like some WD-40 would take care of it. Any help would be appreciated.
Related Models
Maytag MDE5500AYW DRYER- ELE
Maytag MDE5500AZQ DRYER- ELE
Maytag MDE5500AZW DRYER- ELE
Maytag MDE5806AYK DRYER- ELE
Maytag MDE5806AYW DRYER- ELE
Maytag MDE5806AZK DRYER- ELE
Maytag MDE5806AZW DRYER- ELE
Maytag MDE5960AYW DRYER- ELE
Maytag MDE6000AUW DRYER- ELE
Maytag MDE6000AYQ DRYER- ELE
Maytag MDE6000AYW DRYER- ELE
Maytag MDE6000AZQ DRYER- ELE
Maytag MDE6000AZW DRYER- ELE
Maytag MDE6200AYQ DRYER- ELE
Maytag MDE6200AYW DRYER- ELE
Maytag MDE6200AZQ DRYER- ELE
Maytag MDE6200AZW DRYER- ELE
Maytag MDE6400AGW DRYER- ELE
Maytag MDE6400AYQ DRYER- ELE
Maytag MDE6400AYW DRYER- ELE
Maytag MDE6400AZW DRYER- ELE
Maytag MDE6460AYW DRYER- ELE
Maytag MDE6460AZW DRYER- ELE
Maytag MDE6657BYQ DRYER- ELE
Maytag MDE6657BYW DRYER- ELE
Maytag MDE6700AYW DRYER- ELE
Maytag MDE6700AZW DRYER- ELE
Maytag MDE6800AYQ DRYER- ELE
Maytag MDE6800AYW DRYER- ELE
Maytag MDE6800AZQ DRYER- ELE
Maytag MDE6800AZW DRYER- ELE
Maytag MDE7057AYQ DRYER- ELE
Maytag MDE7057AYW DRYER- ELE
Maytag MDE7057AZW DRYER- ELE
Maytag MDE7400AYQ DRYER- ELE
Maytag MDE7400AYW DRYER- ELE
Maytag MDE7400AZQ DRYER- ELE
Maytag MDE7400AZW DRYER- ELE
Maytag MDE7460AYQ DRYER- ELE
Maytag MDE7460AYW DRYER- ELE
Maytag MDE7500AYQ DRYER- ELE
Maytag MDE7500AYW DRYER- ELE
Maytag MDE7500AZQ DRYER- ELE
Maytag MDE7500AZW DRYER- ELE
Admiral MDE7550AGW DRYER- ELE
Maytag MDE7600AUW DRYER- ELE
Maytag MDE7600AYQ DRYER- ELE
Maytag MDE7600AYW DRYER- ELE
Maytag MDE7600AZQ DRYER- ELE
Maytag MDE7600AZW DRYER- ELE
Maytag MDE7657AYQ DRYER- ELE
Maytag MDE7657AYW DRYER- ELE
Maytag MDE7657BYQ DRYER- ELE
Maytag MDE7657BYW DRYER- ELE
Maytag MDE7658AYQ DRYER- ELE
Maytag MDE7658AYW DRYER- ELE
Maytag MDE7658BYQ DRYER- ELE
Maytag MDE7658BYW DRYER- ELE
Maytag MDE7757AYQ DRYER- ELE
Maytag MDE7757AYW DRYER- ELE
Maytag MDE7758AYQ DRYER- ELE
Maytag MDE7758AYW DRYER- ELE
Maytag MDE8000AYQ DRYER- ELE
Maytag MDE8000AYW DRYER- ELE
Maytag MDE8000AZW DRYER- ELE
Maytag MDE8057AYQ DRYER- ELE
Maytag MDE8057AYW DRYER- ELE
Maytag MDE8057AZW DRYER- ELE
Maytag MDE8058AYQ DRYER- ELE
Maytag MDE8058AYW DRYER- ELE
Maytag MDE8400AYQ DRYER- ELE
Maytag MDE8400AYW DRYER- ELE
Maytag MDE8400AZW DRYER- ELE
Maytag MDE8416AYA DRYER- ELE
Maytag MDE8416AYW DRYER- ELE
Admiral MDE8426AAW DRYER- ELE
Admiral MDE8426AGW DRYER- ELE
Maytag MDE8500AYW DRYER- ELE
Maytag MDE8506AYA DRYER- ELE
Maytag MDE8506AYW DRYER- ELE
Maytag MDE8506AZW DRYER- ELE
Admiral MDE8550AGW DRYER- ELE
Admiral MDE8550BGW DRYER- ELE
Maytag MDE8600AYQ DRYER- ELE
Maytag MDE8600AYW DRYER- ELE
Maytag MDE8600AZQ DRYER- ELE
Maytag MDE8600AZW DRYER- ELE
Maytag MDE8757AYQ DRYER- ELE
Maytag MDE8757AYW DRYER- ELE
Maytag MDE9206AYA DRYER- ELE
Maytag MDE9206AYW DRYER- ELE
Maytag MDE9206AZW DRYER- ELE
Maytag MDE9306AUW DRYER- ELE
Maytag MDE9306AYA DRYER- ELE
Maytag MDE9306AYW DRYER- ELE
Maytag MDE9306AZA DRYER- ELE
Maytag MDE9306AZW DRYER- ELE
Maytag MDE9316AYA DRYER- ELE
Maytag MDE9316AYQ DRYER- ELE
Maytag MDE9316AYW DRYER- ELE
Maytag MDE9316AZW DRYER- ELE
Maytag MDE9357AYA DRYER- ELE
Maytag MDE9357AYW DRYER- ELE
Maytag MDE9360AYW DRYER- ELE
Maytag MDE9390AYW DRYER- ELE
Maytag MDE9390AZW DRYER- ELE
Maytag MDE9420AYW DRYER- ELE
Maytag MDE9420AZW DRYER- ELE
Maytag MDE9520AYQ DRYER- ELE
Maytag MDE9520AYW DRYER- ELE
Maytag MDE9520AZW DRYER- ELE
Maytag MDE9557AYA DRYER- ELE
Maytag MDE9557AYQ DRYER- ELE
Maytag MDE9557AYW DRYER- ELE
Maytag MDE9557AZA DRYER- ELE
Maytag MDE9557AZQ DRYER- ELE
Maytag MDE9557AZW DRYER- ELE
Maytag MDE9606AUW DRYER- ELE
Maytag MDE9606AYA DRYER- ELE
Maytag MDE9606AYQ DRYER- ELE
  #2 (permalink)
Old 08-22-2010, 05:22 AM
Senior Expert
APP Volunteer
kayakcrzy will become famous soon enough
Default
Quote:
No on the WD40. Take the front off, there will be 2 phillips head screws on the bottom of the front panel. Then take the wires off the door switch. Then the vent housing needs to come off. There are two 5/16s screws on the right side and 2 on the left side. Once removed the vent housing will pull off. Then go behind the dryer, and take off the small access panel, and remove the belt. Notice how it comes off. Then go back to the front and remove the drum. If you need more room to work the top comes up. There is a 3/8s screw on the bottom side of the front on the left and the right side. Once removed, lift the top up. The parts you would need to replace to insure that you could for another 7 to 10 years are as follows. 2 drums, 1 idler pully wheel, and 1 belt. Parts are resonably cheap. Since you are in there, it is best to do it all. It is a great dryer, and you can do it. Tom ******************************************** - Parts
  #3 (permalink)
Old 08-24-2010, 08:09 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Replacement parts for MAYTAG MDE5500AYW Dryer - Ele | AppliancePartsPros.com
Also check your front glides (bearings) Item 30 in Section 6.
Though usually you get a grinding noise when they wear down.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag loud squeaking when agitating dan11279 Washer Repair 0 06-12-2010 02:20 PM
Loud squeaking Noise Peter687 Dryer Repair 4 09-24-2009 12:01 PM
Loud Squeaking Dryer gahorsegal Dryer Repair 1 01-04-2009 04:21 PM
Loud Squeaking Noise bdmcgal Dryer Repair 1 12-10-2008 07:13 PM
ge dryer is making loud squeaking noise georgepannier@sbcglobal.n Dryer Repair 3 12-28-2007 10:23 PM
