Discuss
Dryer Help: Dryer works fine and turns on fine but will stop heating after 1min
 in
Dryer Repair
Hello., I have a Frigidaire Electric Dryer Model GLEQ2152ES. My dryer had a bad bearing and heating coil so I
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer Help: Dryer works fine and turns on fine but will stop heating after 1min
  #1 (permalink)
Old 08-21-2010, 05:35 AM
Junior Member
missjsmith11 is on a distinguished road
Default Dryer Help: Dryer works fine and turns on fine but will stop heating after 1min
Brand: -brand-   Age: Less than 1 year
Hello., I have a Frigidaire Electric Dryer Model GLEQ2152ES. My dryer had a bad bearing and heating coil so I replace it about 6 months ago. It was working perfect up untill a week ago when my cloth wasnt drying. I went ahead and took a look at it and it seems to work fine for the first 2 minutes of use and then the heating coiling doesn't heat anymore after those 2 minutes.. Just blows air. Anyone have a idea on what the problem might be? Thanks
Another thing, I switch the settings to Towels and it was heating really bad. The heating coils didnt want to stop heating. It ran like this for 4 minutes untill I had to stop it due to it was getting extremely hot.
Ads By Google
  #2 (permalink)
Old 08-21-2010, 05:59 AM
Junior Member
Default
Forgot to add
Sometimes the dryer will heat up extremely HOT, then sometimes it will not heat up at all. The drum spins perfectly and no weird sounds. My guess is that it needs a new Thermistor?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer runs fine...just backwards? ohmondo Dryer Repair 3 12-27-2009 10:12 AM
My dryer does not heat but work fine. synbad37 Dryer Repair 1 10-14-2009 07:18 AM
dryer works fine but no heat and wont shut off misty_mikie Dryer Repair 0 08-23-2009 02:37 PM
Dryer Runs Fine But It Squeeks kimflinn@zoominternet.net Dryer Repair 0 04-25-2009 11:50 AM
dryer won't turn belt fine alison Dryer Repair 1 11-16-2008 07:07 AM
