Discuss
squeeky dryer
 in
Dryer Repair
My washer and dryer are only 3 years old and having some problems. (They are stackable models). I was out
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » squeeky dryer
  #1 (permalink)
Old 08-20-2010, 08:12 PM
Junior Member
shorembo is on a distinguished road
Default squeeky dryer
Model Number: LEQ2152ES0   Brand: Frigidaire   Age: 1 - 5 years
My washer and dryer are only 3 years old and having some problems. (They are stackable models). I was out of town and my wife had a repairman come by. He said that the washer was going bad and the dryer needed a new heating element and the bearings were going bad and recommended buying new ones. My impression is that he seemed to not want to deal with large stackables in a small closet .
Anyways, we didn't really get anything done.
As far as the dryer goes, it had started to squeek recently. How hard is it to make the bearing and heating element repairs? And where can I get some instructions?
Ads By Google
Related Models
Frigidaire LEQ2152ES0 Frigidaire/electric Dryer
Frigidaire LEQ332DS0 Frigidaire/dryer
Whirlpool LEQ5000KQ0
Whirlpool LEQ5000KQ1 29"electric Dryer
Whirlpool LEQ5000KQ2 29"electric Dryer
Whirlpool LEQ5000KW1 29"electric Dryer
Whirlpool LEQ5000KW2 29"electric Dryer
Whirlpool LEQ5000PW0 29"electric Dryer
Frigidaire LEQ6000ES0 Frigidaire/dryer
Frigidaire LEQ6000ES1 Frigidaire/dryer
Frigidaire LEQ6000ES2 Frigidaire/electric Dryer
Frigidaire LEQ642DS0 Frigidaire/dryer
Frigidaire LEQ7000EG0 Frigidaire/dryer
Frigidaire LEQ7000ES0 Frigidaire/dryer
Frigidaire LEQ7000ES1 Frigidaire/dryer
Frigidaire LEQ7000ES2 Frigidaire/dryer
Whirlpool LEQ7000KQ0
Whirlpool LEQ7000KQ1
Whirlpool LEQ7000KQ2
Whirlpool LEQ7030KQ0
Whirlpool LEQ7030KQ1
Whirlpool LEQ7030KQ2 29"electric Dryer
Whirlpool LEQ8000HQ0
Whirlpool LEQ8000HQ1
Whirlpool LEQ8000JQ0
Whirlpool LEQ8000JQ1
Whirlpool LEQ8000JQ2
Whirlpool LEQ8000JQ3 29"electric Dryer
Whirlpool LEQ8000JQ4 Electric Dryer
Whirlpool LEQ8100KQ0
Whirlpool LEQ8100KQ1
Whirlpool LEQ8100KT0
Whirlpool LEQ8100KT1
Whirlpool LEQ8611LG0
Whirlpool LEQ8611LG1 27"electric Dryer
Whirlpool LEQ8611LW0
Whirlpool LEQ8611LW1 27"electric Dryer
Whirlpool LEQ8611PG0 27" Electric Dryer
Whirlpool LEQ8611PG1 27"electric Dryer
Whirlpool LEQ8611PG2 27"electric Dryer
Whirlpool LEQ8611PW0 27" Electric Dryer
Whirlpool LEQ8611PW1 27"electric Dryer
Whirlpool LEQ8611PW2 27"electric Dryer
Whirlpool LEQ8621PG0 27" Electric Dryer
Whirlpool LEQ8621PG1 27"electric Dryer
Whirlpool LEQ8621PG2 27"electric Dryer
Whirlpool LEQ8621PW0 27" Electric Dryer
Whirlpool LEQ8621PW1 27"electric Dryer
Whirlpool LEQ8621PW2 27"electric Dryer
Whirlpool LEQ8800JQ0
Whirlpool LEQ8800JQ1
Whirlpool LEQ8800JT0
Whirlpool LEQ8800JT1
Whirlpool LEQ8857HQ0
Whirlpool LEQ8857HQ1
Whirlpool LEQ8857HZ0
Whirlpool LEQ8857HZ1
Whirlpool LEQ8857JQ0
Whirlpool LEQ8857JQ1
Whirlpool LEQ8857JT0
Whirlpool LEQ8857JT1
Whirlpool LEQ8858HQ0
Whirlpool LEQ8858HQ1
Whirlpool LEQ8858HZ0
Whirlpool LEQ8858HZ1
Whirlpool LEQ8858JQ0
Whirlpool LEQ8858JQ1
Whirlpool LEQ8858JT0
Whirlpool LEQ8858JT1
Whirlpool LEQ8858JZ0
Whirlpool LEQ8858JZ1
Whirlpool LEQ9030PQ0 29"electric Dryer
Whirlpool LEQ9030PQ1 29" Electric Dryer
Whirlpool LEQ9508KQ0
Whirlpool LEQ9508LG0
Whirlpool LEQ9508LW0
Whirlpool LEQ9508LW1 29"electric Dryer
Whirlpool LEQ9508PG0 29"electric Dryer
Whirlpool LEQ9508PG1 29" Electric Dryer
Whirlpool LEQ9508PW0 29"electric Dryer
Whirlpool LEQ9508PW1 29" Electric Dryer
Whirlpool LEQ9557KQ1
Whirlpool LEQ9557KT1
Whirlpool LEQ9558KQ0
Whirlpool LEQ9558KQ1
Whirlpool LEQ9558KT0
Whirlpool LEQ9558KT1
Whirlpool LEQ9857LG0
Whirlpool LEQ9857LG1 29"electric Dryer
Whirlpool LEQ9857LW0
Whirlpool LEQ9857LW1 29"electric Dryer
Whirlpool LEQ9857PW0 29"electric Dryer
Whirlpool LEQ9858LG0
Whirlpool LEQ9858LG1 29"electric Dryer
Whirlpool LEQ9858LW0
Whirlpool LEQ9858LW1 29"electric Dryer
Whirlpool LEQ9858PG0 29"electric Dryer
Whirlpool LEQ9858PG1 29"electric Dryer
Whirlpool LEQ9858PW0 29"electric Dryer
Whirlpool LEQ9858PW1 29"electric Dryer
Whirlpool LEQ9957KQ0
Whirlpool LEQ9957KT0
Admiral LER1115AAW Range - F/s Std Ele
Whirlpool LER2614BW0
Whirlpool LER2614BW1
Whirlpool LER2614BW2
Whirlpool LER2614DW0
Whirlpool LER2614DW1
Whirlpool LER2614EW0
Whirlpool LER2614EW1
Whirlpool LER2614EW2
Whirlpool LER2614JQ0
Whirlpool LER2614JQ1
Whirlpool LER2614JQ2 29"electric Dryer
Frigidaire LER331DS0 Frigidaire/dryer
Admiral LER3330AAB Range - S/c F/s Ele
Admiral LER3330AAW Range - S/c F/s Ele
Admiral LER3330AAZ Range - S/c F/s Ele
Whirlpool LER3422AN0
Whirlpool LER3422AW0
  #2 (permalink)
Old 08-21-2010, 05:49 AM
Junior Member
missjsmith11 is on a distinguished road
Default
I replaced my heating coil and rear bearing about 6 months ago. It honestly isn't hard. Its about a 3/10 in your DoItYourself scale. Make sure you have a helping hand, It doesn't hurt.
Here is your dryers guide/manuel.
http://www.frigidaire.com/products/h...ers/gleq2152es
Download the Installation Instructions
Your dryer is pretty much the same as the one I have. Good luck.
  #3 (permalink)
Old 08-21-2010, 06:33 AM
Junior Member
Default
Thanks for the response. I found the parts guide and can find the parts to order. Just one last question that I can't seem to figure out (prior to taking the stackable dryer down). This is kinda stupid but for installing, is it all done through a back panel or is there a front panel, or something else.
  #4 (permalink)
Old 08-21-2010, 08:44 AM
Junior Member
Default
Quote:
If you need to replace the rear bearing and heating coil you are going to have to remove the drum. You are more then likely going to have to remove the front door/control panel/ front panel and then remove the drum. Once you remove the drum you will see if your rear bearing attact to it. The heating element/coil will be screwed into the back of your dryer but 4 screws. Please be sure to remove all power prior to disabling your dryer
If you need help on how to remove or get the basic concept of doing so. I suggest you go to youtube and watch some videos. Type "rear bearing dryer" and "dryer Heating Element"
Here is a video of how your dryer should look like inside. Trust me it will.
YouTube - Frigidaire heavyduty dryer part 1.avi Part 1
YouTube - Frigidaire heavyduty dryer part 2.avi part 2
  #5 (permalink)
Old 08-22-2010, 12:36 PM
Junior Member
Default
THANKS!!!!
The youtube video made the job incredibly easy. Thanks a million. My 19 year old son helped me and said that it was a simple fix. It seems like the biggest problem is finding how to take it apart.
Anyways...onwards to the leaky washer.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
squeeky dryer jooey2 Dryer Repair 1 07-19-2010 03:12 PM
Dryer has squeeky sound. bobobo Dryer Repair 0 04-01-2010 04:09 PM
Squeeky dryer Stonehenge Dryer Repair 1 01-13-2010 01:11 AM
Squeeky Dryer Squeeky Dryer Dryer Repair 1 07-03-2009 05:42 AM
squeeky dryer clayandlin Dryer Repair 1 02-09-2009 11:58 AM
