I have a gas dryer that heats up then cools down after a couple minutes.
When I start the dryer the igniter glows and then a few seconds later the blue flames appear and the dryer heats up. After 2-3 miutes the blue flame goes out and the dryer cools down.
Please let me know how to trouble shoot or what I need to replace. I have already replaced the igniter.
Thanks, Dave
Groups: Expert
Joined: 7/27/2010(UTC) Posts: 1,395 Location: near the middle of nowhere Was thanked: 24 time(s) in 24 post(s)
Originally Posted by: dave dorenkamp I have a gas dryer that heats up then cools down after a couple minutes.
Thanks, Dave I would get this coil set and once installed you should be good to go. Part number: AP3094251
They are probably the most common failure on a gas dryer.
