Discuss
how to replace dryer belt
 in
Dryer Repair
How do I replace the dryer belt on my machine
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » how to replace dryer belt
  #1 (permalink)
Old 09-18-2007, 03:16 PM
donnao donnao is offline
Junior Member
donnao is on a distinguished road
Question how to replace dryer belt
Model Number: FDE436RBS1   Brand: Frigidaire   Age: More than 10 years
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-27-2008, 01:01 PM
swtmama5 swtmama5 is offline
Junior Member
swtmama5 is on a distinguished road
Default belt replace
How do you replace the belt for the drum in your dryer
  #3 (permalink)
Old 01-28-2008, 05:19 AM
richappy richappy is online now
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
Pull the front panel off, remove the top screws and tilt top back. Rout the new belt around drum at the old wear spot with the grooved side against the drum. Next remove the back access door and rout the belt around the idler pulley and motor pulley. There is only one way to do this and get proper tension on the belt.
Also, when you order the belt, ask if it has a belt routing diagram on the belt package.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
dryer belt replacement mamasue Dryer Repair 0 08-14-2007 10:00 AM
Replacement of Dryer Belt kcbrandt11 Dryer Repair 0 08-02-2007 03:25 PM
Need to replace door hinges on dryer jherman Dryer Repair 1 07-28-2007 04:07 PM
Dryer Tub Belt ColleenR Dryer Repair 0 07-26-2007 09:39 PM
how to put a belt on my dryer radracemom Dryer Repair 1 07-23-2007 05:47 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
