Bedrock
#1 Posted : Tuesday, August 17, 2010 7:07:23 PM(UTC)
Bedrock
I have read several posts concerning this problem and I am getting a little confused as where to start. The gas flame ignites and then goes out after a few minutes. The igniter glow a few minutes later but the flame does not start. If I wait and let everything cool down, it will heat up but only for a few minutes again. Okay, so I have taken it apart and checked of obstructions, included the vent to the exterior. Blower fan workes fine. Flame is blue. Which parts should I start with first or should I just replace the parts that keep coming up in the posts. (gas coil, thermal fuse, heating element, igniter, thermostats, etc)
Thanks,
Bedrock
kayakcrzy
#2 Posted : Wednesday, August 18, 2010 4:01:35 AM(UTC)
kayakcrzy
Thanks,
Bedrock
Replace the coils on the gasd valve, and that will do the trick. The secondary coil is bad, that is why it starts at first, and then not after that. Quick, and easy repair, and you don't have to shut the gas off to do it. Tom ApplianceEducator.com - Parts
Bedrock
#3 Posted : Friday, August 20, 2010 3:24:36 AM(UTC)
Bedrock
Tom,
Thanks. It works perfectly now. You were a great help.
Bedrock:)
kayakcrzy
#4 Posted : Friday, August 20, 2010 3:44:30 AM(UTC)
kayakcrzy
Tom,
Bedrock:)
Good Job!!!! Tom ApplianceEducator.com
Kenmore Gas Dryer Won't Maintain Heat (Dryer Repair)
by calenbd 9/28/2008 11:01:18 AM(UTC)
