Discuss
Noisy Dryer
 in
Dryer Repair
My dryer makes a horrible screeching noise whenever it runs. I figure it's the belt or the rollers or bearings,
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Noisy Dryer
  #1 (permalink)
Old 08-17-2010, 11:34 AM
Junior Member
juneschild is on a distinguished road
Default Noisy Dryer
Model Number: CDE6505W   Brand: Crosley   Age: 1 - 5 years
My dryer makes a horrible screeching noise whenever it runs. I figure it's the belt or the rollers or bearings, but I am having trouble pinpointing the source since I can't seem to get the cabinet apart to get to the drum. I was able to remove a couple screws and get a peek at the top of the drum and the belt, which appeared to be fine. I know that the rollers are located under the drum, but the darn cabinet seems to be connected everywhere, no matter how many screws I remove. Any suggestions would be appreciated. Thanks!
Ads By Google
Related Models
Crosley CDE6505W Dryer - Ele
Crosley CDE7000W Dryer - Ele
Crosley CDE7500AZW Dryer - Ele
Crosley CDE7500Q Dryer - Ele
Crosley CDE7500W Dryer - Ele
Crosley CDE8000A Dryer - Ele
Crosley CDE8000AZW Dryer - Ele
Crosley CDE8000W Dryer - Ele
Maytag CDE806 Dryer - Ele
Maytag CDE820 Range - S/c F/s Ele
Maytag CDE8300ACB Range - S/c F/s Ele
Maytag CDE8300ADB Range - S/c F/s Ele
Maytag CDE850 Range - S/c F/s Ddraft Ele
Crosley CDE8500AZW Dryer - Ele
Crosley CDE8500W Dryer - Ele
Maytag CDE851 Range - S/c F/s Ddraft Ele
Maytag CDE852 Range - S/c F/s Ddraft Ele
Maytag CDE8520ACB Range - S/c F/s Ddraft Ele
Crosley CDE8630 Dryer - Ele
Crosley CDE863000 Dryer - Ele
Crosley CDE8630A Dryer - Ele
Crosley CDE8630H Dryer - Ele
Crosley CDE9500AZW Dryer - Ele
Crosley CDE9500W Dryer - Ele
Crosley CDE9505AZW Dryer - Ele
Crosley CDE9505W Dryer - Ele
 CDEC400FW0 CROSLEY/DRYER
 CDG2000FW0 CROSLEY/DRYER
Crosley CDG20C7 Dryer - Gas
Crosley CDG20C700 Dryer - Gas
Crosley CDG20C724 Dryer - Gas
Crosley CDG20C725 Dryer - Gas
Crosley CDG20C7A Dryer - Gas
Crosley CDG20C7H Dryer - Gas
Crosley CDG20M6 Dryer - Gas
Crosley CDG20M6A Dryer - Gas
Crosley CDG20M6H Dryer - Gas
Crosley CDG20M8 Dryer - Gas
Crosley CDG20M800 Dryer - Gas
Crosley CDG20M824 Dryer - Gas
Crosley CDG20M825 Dryer - Gas
Crosley CDG20M8A Dryer - Gas
Crosley CDG20M8D Dryer - Gas
Crosley CDG20P6A Dryer - Gas
Crosley CDG20P6AC Dryer - Gas
Crosley CDG20P6H Dryer - Gas
Crosley CDG20P6HC Dryer - Gas
Crosley CDG20P6W Dryer - Gas
Crosley CDG20P6WC Dryer - Gas
Crosley CDG20P7A Dryer - Gas
Crosley CDG20P7AC Dryer - Gas
Crosley CDG20P7H Dryer - Gas
Crosley CDG20P7W Dryer - Gas
Crosley CDG20P7WC Dryer - Gas
Crosley CDG20P8A Dryer - Gas
Crosley CDG20P8AC Dryer - Gas
Crosley CDG20P8D Dryer - Gas
Crosley CDG20P8DC Dryer - Gas
Crosley CDG20P8DW Dryer - Gas
Crosley CDG20P8HC Dryer - Gas
Crosley CDG20P8W Dryer - Gas
Crosley CDG20P8WC Dryer - Gas
Crosley CDG20R7 Dryer - Gas
Crosley CDG20R7A Dryer - Gas
Crosley CDG20R7AC Dryer - Gas
Crosley CDG20R7H Dryer - Gas
Crosley CDG20R7W Dryer - Gas
Crosley CDG20R7WC Dryer - Gas
Crosley CDG20T6A Dryer - Gas
Crosley CDG20T6W Dryer - Gas
Crosley CDG20T7A Dryer - Gas
Crosley CDG20T7W Dryer - Gas
Crosley CDG20T8A Dryer - Gas
Crosley CDG20T8V Dryer - Gas
Crosley CDG20T8W Dryer - Gas
Crosley CDG22B6M Dryer - Gas
Crosley CDG22B6V Dryer - Gas
Crosley CDG22B7M Dryer - Gas
Crosley CDG22B7V Dryer - Gas
Crosley CDG22B8M Dryer - Gas
Crosley CDG22B8V Dryer - Gas
Maytag CDG306 Dryer - Gas
Maytag CDG307 Dryer - Gas
Maytag CDG308 Dryer - Gas
 CDG4000FW0 CROSLEY/DRYER
Maytag CDG406 Dryer - Gas
Maytag CDG407 Dryer - Gas
Maytag CDG408 Dryer - Gas
Crosley CDG4205AWJ Dryer - Gas
Crosley CDG4205AWW Dryer - Gas
 CDG5000FW0 CROSLEY/DRYER
Crosley CDG6000A Dryer - Gas
Crosley CDG6000Q Dryer - Gas
Crosley CDG6000W Dryer - Gas
Maytag CDG606 Dryer - Gas
Crosley CDG6500Q Dryer - Gas
Crosley CDG6500W Dryer - Gas
Crosley CDG6505W Dryer - Gas
Crosley CDG7000A Dryer - Gas
Crosley CDG7000W Dryer - Gas
Crosley CDG7500Q Dryer - Gas
Crosley CDG7500W Dryer - Gas
Crosley CDG8000A Dryer - Gas
Crosley CDG8000W Dryer - Gas
Maytag CDG806 Dryer - Gas
Crosley CDG8500W Dryer - Gas
Crosley CDG9500W Dryer - Gas
Crosley CDG9505W Dryer - Gas
Frigidaire CDH13E1
Frigidaire CDH13E2
Frigidaire CDH15E1
Frigidaire CDH15E2
Crosley CDH15M Dehumidifier
Crosley CDH15M-02 Dehumidifier
Crosley CDH15M-04 Dehumidifier
Frigidaire CDH25E1
Frigidaire CDH25E2
Frigidaire CDH25E3
Crosley CDH25K Dehumidifier
Crosley CDH25L Dehumidifier
  #2 (permalink)
Old 08-18-2010, 02:14 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Here is the parts breakdown includes the wiring diagram.
Replacement parts for CROSLEY CDE6505W Dryer - Ele | AppliancePartsPros.com
Here is a manual
http://www.servicematters.com/maytag...s/16026315.pdf
Check the rear support rollers, the idler wheel, the motor and the front glides.
Also check the belt for cracks.
Since you have it open you might as well check/clean everthing else. Basically give it an ovehaul.
Also a good time to clean/check your vent system.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer Noisy foxk49 Dryer Repair 1 06-27-2009 05:09 PM
noisy dryer lramsey00 Dryer Repair 2 01-21-2009 05:12 AM
Noisy dryer Davyd Dryer Repair 2 07-09-2008 06:56 PM
noisy dryer james steward Dryer Repair 1 03-17-2008 08:02 PM
noisy dryer curiostech Dryer Repair 0 02-10-2008 11:06 AM
