| » info |
Model Number: mde9700ayw Brand: Maytag Age: 1 - 5 years
How do you replace heating element?
Console Removal 1. Disconnect power supply to unit. 3. Remove two screws mounting the Heater PCB Board2. Remove Top Cover. 4. Disconnect the black and white connectors. 5. Remove four screws attaching Console to washer dryer. 6. Rotate Console down and remove from dryer5. Remove two screws in the door area. 6. Pull Front Panel forward and disconnect the Interior Light harness. 7. Lift the Front Panel off the three tabs across the bottom and remove. Heater Assembly Removal 1. Disconnect power supply to unit. 5. Remove Heater Assembly retaining screw.2. Remove Top Cover. 3. Remove Console. 4. Remove Front Cover. 6. Slide Heater Assembly out the front of dryer.. 7. Remove the wiring terminals from the Heater assembly.
__________________
Thanks for allowing AppliancePartsPros.com to assist you, Joe M. APP TEAM Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
| Display Modes | |
| Need info please | rnh540 | Refrigerator & Freezer Repair | 1 | 02-20-2009 04:47 PM |
