Discuss
Low Air flow
 in
Dryer Repair
The dryer heats-up but does not seem to be moving enough air. I have checked for obstructions and cleaned the
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Low Air flow
  #1 (permalink)
Old 08-15-2010, 10:43 AM
Junior Member
minnigb is on a distinguished road
Default Low Air flow
Model Number: LER5636KQ0   Brand: Whirlpool   Age: 5 - 10 years
The dryer heats-up but does not seem to be moving enough air. I have checked for obstructions and cleaned the duct and dryer internally.
It will dry a very small load anything near normal will take several cycles. The problem has been getting progressively worse.
Everything appears to check out electrically.
Related Models
Whirlpool LER5636KQ0 RESIDENTIAL DRYER
Whirlpool LER5636KQ1 RESIDENTIAL DRYER
Whirlpool LER5636KT0 RESIDENTIAL DRYER
Whirlpool LER5636KT1 RESIDENTIAL DRYER
Whirlpool LER5636LG0
Whirlpool LER5636LQ0
Whirlpool LER5636LQ1 29"ELECTRIC DRYER
Whirlpool LER5636LT0
Whirlpool LER5636LT1 29"ELECTRIC DRYER
Whirlpool LER5636LW0
Whirlpool LER5636PQ0 29"ELECTRIC DRYER
Whirlpool LER5636PQ1 29"ELECTRIC DRYER
Whirlpool LER5636PT0 29"ELECTRIC DRYER
Whirlpool LER5636PT1 29"ELECTRIC DRYER
Whirlpool LER5638AN1 ELECTRIC DRYER
Whirlpool LER5638AN2 ELECTRIC DRYER
Whirlpool LER5638AN3 ELECTRIC DRYER
Whirlpool LER5638AW0 Residential Dryer
Whirlpool LER5638AW1 ELECTRIC DRYER
Whirlpool LER5638AW2 ELECTRIC DRYER
Whirlpool LER5638AW3 ELECTRIC DRYER
Whirlpool LER5644AN1
Whirlpool LER5644AN2 ELECTRIC DRYER
Whirlpool LER5644AW0 Residential Dryer
Whirlpool LER5644AW1
Whirlpool LER5644AW2 ELECTRIC DRYER
Whirlpool LER5644EQ0 ELECTRIC DRYER
Whirlpool LER5644EQ1 ELECTRIC DRYER
Whirlpool LER5644EQ2 ELECTRIC DRYER
Whirlpool LER5644EZ0 ELECTRIC DRYER
Whirlpool LER5644EZ1 ELECTRIC DRYER
Whirlpool LER5644EZ2 ELECTRIC DRYER
Whirlpool LER5644JQ0 DRYER
Whirlpool LER5644JQ1 DRYER
Whirlpool LER5644JQ2 RESIDENTIAL DRYER
Whirlpool LER5644JQ3 29"ELECTRIC DRYER
Whirlpool LER5644JT0 DRYER
Whirlpool LER5644JT1 DRYER
Whirlpool LER5644JT2 RESIDENTIAL DRYER
Whirlpool LER5644JT3 29"ELECTRIC DRYER
Whirlpool LER5644PQ0 29"ELECTRIC DRYER
Whirlpool LER5644PQ1 29"ELECTRIC DRYER
Whirlpool LER5700KQ0 RESIDENTIAL DRYER
Whirlpool LER5700KQ1 RESIDENTIAL DRYER
Whirlpool LER5700KT0 RESIDENTIAL DRYER
Whirlpool LER5700KT1 RESIDENTIAL DRYER
Whirlpool LER5848EQ0 ELECTRIC DRYER
Whirlpool LER5848EQ1 ELECTRIC DRYER
Whirlpool LER5848EQ2 ELECTRIC DRYER
Whirlpool LER5848EQ3 DRYERS
Whirlpool LER5848EQ4 DRYERS
Whirlpool LER5848EQ5 ELECTRIC DRYER
Whirlpool LER6611LQ0 RESIDENTIAL DRYER
Whirlpool LER6611LQ1 29"ELECTRIC DRYER
Whirlpool LER6611PQ0 29" ELECTRIC DRYER
Whirlpool LER6620PQ0 29"ELECTRIC DRYER
Whirlpool LER6620PQ1 29"ELECTRIC DRYER
Whirlpool LER6620PT0 29"ELECTRIC DRYER
Whirlpool LER6620PT1 29"ELECTRIC DRYER
Whirlpool LER6621PQ0 29" ELECTRIC DRYER
Whirlpool LER6634BN0 ELECTRIC DRYER
Whirlpool LER6634BN1 ELECTRIC DRYER
Whirlpool LER6634BN2 ELECTRIC DRYER
Whirlpool LER6634BQ0 ELECTRIC DRYER
Whirlpool LER6634BQ1 ELECTRIC DRYER
Whirlpool LER6634BQ2 ELECTRIC DRYER
Whirlpool LER6634BW0 ELECTRIC DRYER
Whirlpool LER6634BW1 ELECTRIC DRYER
Whirlpool LER6634BW2 ELECTRIC DRYER
Whirlpool LER6634DQ0 ELECTRIC DRYER
Whirlpool LER6634DQ1 ELECTRIC DRYER
Whirlpool LER6634DW0 ELECTRIC DRYER
Whirlpool LER6634DW1 ELECTRIC DRYER
Whirlpool LER6634DZ0 ELECTRIC DRYER
Whirlpool LER6634DZ1 ELECTRIC DRYER
Whirlpool LER6636PW0 29" ELECTRIC DRYER
Whirlpool LER6636PW1 29" ELECTRIC DRYER
Whirlpool LER6638DQ0 ELECTRIC DRYER
Whirlpool LER6638DQ1 ELECTRIC DRYER
Whirlpool LER6638DW0 ELECTRIC DRYER
Whirlpool LER6638DW1 ELECTRIC DRYER
Whirlpool LER6638DZ0 ELECTRIC DRYER
Whirlpool LER6638DZ1 ELECTRIC DRYER
Whirlpool LER6644DQ0 ELECTRIC DRYER
Whirlpool LER6644DQ1 ELECTRIC DRYER
Whirlpool LER6644DZ0 ELECTRIC DRYER
Whirlpool LER6644DZ1 ELECTRIC DRYER
Whirlpool LER6646BN0 ELECTRIC DRYER
Whirlpool LER6646BN1 ELECTRIC DRYER
Whirlpool LER6646BN2 ELECTRIC DRYER
Whirlpool LER6646BW0 ELECTRIC DRYER
Whirlpool LER6646BW1 ELECTRIC DRYER
Whirlpool LER6646BW2 ELECTRIC DRYER
Whirlpool LER6646DN1 ELECTRIC DRYER
Whirlpool LER6646DW1 ELECTRIC DRYER
Whirlpool LER6646PW0 29" ELECTRIC DRYER
Whirlpool LER6646PW1 29" ELECTRIC DRYER
Whirlpool LER6848AN1 ELECTRIC DRYER
Whirlpool LER6848AN2 ELECTRIC DRYER
Whirlpool LER6848AQ2 ELECTRIC DRYER
Whirlpool LER6848AW0 Residential Dryer
Whirlpool LER6848AW1 ELECTRIC DRYER
Whirlpool LER6848AW2 ELECTRIC DRYER
Whirlpool LER6848AZ2 ELECTRIC DRYER
Whirlpool LER7620KQ0 RESIDENTIAL DRYER
Whirlpool LER7620KQ1 ELECTRIC DRYER
Whirlpool LER7620KT0 DRYER
Whirlpool LER7620KT1 ELECTRIC DRYER
Whirlpool LER7620LG0 RESIDENTIAL DRYER
Whirlpool LER7620LG1 29"ELECTRIC DRYER
Whirlpool LER7620LQ0 RESIDENTIAL DRYER
Whirlpool LER7620LW0 RESIDENTIAL DRYER
Whirlpool LER7620LW1 29"ELECTRIC DRYER
Whirlpool LER7646AN0 ELECTRIC DRYER
Whirlpool LER7646AN1 ELECTRIC DRYER
Whirlpool LER7646AN2 ELECTRIC DRYER
Whirlpool LER7646AQ0 ELECTRIC DRYER
Whirlpool LER7646AQ1 ELECTRIC DRYER
Whirlpool LER7646AQ2 ELECTRIC DRYER
Whirlpool LER7646AW0 Residential Dryer
  #2 (permalink)
Old 08-17-2010, 06:02 PM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
Did you take off the lint chute and clean it out??
__________________
  #3 (permalink)
Old 08-18-2010, 02:56 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Did you check that the blower wheel was tight on the motor shaft and not slipping? Also heavy dirt/dust on the blower vanes can greatly reduce air flow.
Have you checked the lint screen, sometimes it can get coated with fabric softener residue and has to be cleaned with soap and water?
When you cleaned your vent system did you also check that the outside vent louvers opened correctly?
The following is one way to help isolate the problem.
Undo the dryer from the exhaust
Run a load
If the load dries correctly then you have a vent problem.
Clean/check the vent system. Make sure the outside louvers open fully.
If you do not want lint in the house.
Take a pair of pantyhose, put one leg into the other and attach this to the dryer exhaust.
Leave enough room behind the dryer so it can blow out like a windsock.
Run a load.
Both the above will allow you to check the air flow and temp.
Also the above is NOT recommended for a gas dryer due to possible carbon monoxide problems
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
no gas flow Loren Gross Oven Repair (including Ranges and Cooktops) 0 04-23-2010 07:04 PM
The gas won't flow mkyes Oven Repair (including Ranges and Cooktops) 1 12-15-2009 03:10 PM
No Air Flow paulmaudlin Oven Repair (including Ranges and Cooktops) 1 07-03-2009 08:31 PM
air flow fan samson11 Refrigerator & Freezer Repair 3 05-31-2009 09:51 PM
Water over flow vincentford Washer Repair 1 10-17-2008 06:27 PM
