Discuss
Kenmore Gas Dryer - Runs without heat
 in
Dryer Repair
This will probably be very simple and I have done some research so hopefully this will confirm what I have
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Kenmore Gas Dryer - Runs without heat
  #1 (permalink)
Old 08-29-2008, 07:28 AM
lil2spunki lil2spunki is offline
Junior Member
lil2spunki is on a distinguished road
Question Kenmore Gas Dryer - Runs without heat
Model Number: 11073032102   Brand: Kenmore   Age: 5 - 10 years
This will probably be very simple and I have done some research so hopefully this will confirm what I have learned. My dryer runs but the heat never kicks on. I don't hear it attempt to ignite the heat. I have cleaned out any lint and debris (which was not alot) from the vents.
I would like to get my parts ordered today and I am not quite sure which part to start with. Should I just go ahead an order a thermal fuse and see if that does the trick or should I also order the thermostat in conjunction with the fuse?
Thanks for any advice.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
dryer runs but no heat ompong Dryer Repair 4 06-20-2008 07:48 PM
Kenmore 60 Series(gas) Runs but wont heat PJM Dryer Repair 0 02-02-2008 07:09 AM
Dryer runs but will not heat falgmatp Dryer Repair 1 10-14-2007 04:33 AM
Kenmore runs but won't heat kbarr Dryer Repair 2 08-09-2007 05:26 PM
Dryer runs but doesn't heat Jane Dryer Repair 6 08-07-2007 10:01 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
