Discuss
No Heat when drying (Gas)
 in
Dryer Repair
No heat while drying clothes. Think it might be ignitor. How can I find electrical information/diagram for this Gas
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » No Heat when drying (Gas)
  #1 (permalink)
Old 09-17-2007, 08:13 PM
RoadKing RoadKing is offline
Junior Member
RoadKing is on a distinguished road
Question No Heat when drying (Gas)
Model Number: LDG8506AAE   Brand: Maytag   Age: More than 10 years
No heat while drying clothes. Think it might be ignitor. How can I find electrical information/diagram for this Gas unit. For example, when I measured input to ignitor, it was approx 27 volts, was sort of expecting 110-120.
I am guessing it could be ignitor or thermal fuse? Any and all suggestions on fixing this would be appreciated.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 09-18-2007, 02:39 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
Click on your model# for the schematic. You will need to check all components upstream from the gas assembly and all connectors. Check overload and cycling thermostat,thermal fuse and timer.
__________________
  #3 (permalink)
Old 09-20-2007, 03:43 PM
Junior Member
Question
Richappy,
Thanks, but I need to ask.....what should measurements read? In other words when I measured the voltage feeding Ignitor to be 27v, was that good or low and it should have been 110/120? I figure I can check for simple continuity on the thermal fuse, but question would be where to find?
I know these are probably some dumb questions, but I'm just trying to fix the dryer without re-purchasing it, or having to buy a new one.....
Best Regards,
David
  #4 (permalink)
Old 10-06-2007, 02:41 PM
Junior Member
Default Problem solved
Richappy
Looks like it was actually the Flame/Radiant Sensor.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
No or limited heat during drying cycle roles120 Dryer Repair 4 09-11-2008 04:06 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
