Discuss
Need Help with dryer
 in
Dryer Repair
Timer counts down on all cycles but does not go to the off position, will continue to run until manually
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Need Help with dryer
  #1 (permalink)
Old 08-27-2008, 01:51 PM
pahokee58 pahokee58 is offline
Junior Member
pahokee58 is on a distinguished road
Default Need Help with dryer
Model Number: LER4634EQ2   Brand: Whirlpool   Age: 5 - 10 years
Timer counts down on all cycles but does not go to the off position, will continue to run until manually turning knob to off position.
Replaced timer switch but is still happening.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 08-27-2008, 07:55 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Quote:
Originally Posted by pahokee58 View Post
...Replaced timer switch but is still happening...
When you said "timer switch" you meant the timer or something else?
It does not go to the off position on all cycles or on "auto" only? Did you try the timed cycle?
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 08-28-2008, 05:50 AM
Junior Member
Default
It does not shut off on all cycles. Timed cycle or any other setting, it will count down but at the end it continues to run until you turn the knob to the off position manually.
  #4 (permalink)
Old 08-28-2008, 06:34 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by Gene View Post
...When you said "timer switch" you meant the timer or something else?...
I need you to answer this question too.
__________________
  #5 (permalink)
Old 08-29-2008, 05:48 AM
Junior Member
Default
I replaced the whole control switch, I believe it was Model m460g ? It is the switch that controls the knob for dryer settings. Thanks
  #6 (permalink)
Old 08-29-2008, 11:15 AM
Gene's Avatar
Senior Expert
APP Volunteer
Default
What is the part number of the "switch" you replaced?
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
