| » Need Help with dryer |
Model Number: LER4634EQ2 Brand: Whirlpool Age: 5 - 10 years
Timer counts down on all cycles but does not go to the off position, will continue to run until manually turning knob to off position.
Replaced timer switch but is still happening. |
When you said "timer switch" you meant the timer or something else?
It does not go to the off position on all cycles or on "auto" only? Did you try the timed cycle? Gene.
__________________
Professional appliance repair in Los Angeles, California. |
Quote:
__________________
What is the part number of the "switch" you replaced?
__________________
| Display Modes | |
